Fuel Octane?
Discussion in 'Gen 2 Prius Fuel Economy' started by jamesrm, May 1, 2008.
  1. jamesrm
    jamesrm Junior Member
    Mid TN
    Do you notice any FE by purchasing premium fuel, or do you just stick with the 87?
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    17
    It will make NO difference in FE . . . just the relative size of the hole in your wallet.
  3. HardCase
    HardCase SilverPineMica, the green one
    408
    Kalispell, Montana
    You might catch some jazz for asking this question. It has been asked and answered on here dozens of times. Same with "How do you disable the reverse beep?" and "What are the best tires for the Prius?" The search function actually works fairly well on this site. Happy reading.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Higher octane gas may reduce your mileage. At the very least, it won't help.
    Tom
  5. ECHELON
    ECHELON New Member
    39
    Mississauga, Ontario, Canada
    Pound for pound, there is pretty much no difference. However, some companies like to put 10% ethanol on 87, and 0% on 91 - hence why you might see an mpg boost with 91 over 87. Shell is like that...at least up here in Canada. You might want to check with your local gas station to find out.
  6. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    127
    Papillion, Nebraska
    I'm sure someone on here has figured this out, but is it cheaper to pay $.10 extra for 87 octane (like we have to here) over 89 octane to avoid the ethanol since the ethanol blend tends to reduce fuel economy?
