Fuel pressure zero
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by GhostmanOn3rd, Nov 20, 2021.
  1. GhostmanOn3rd
    GhostmanOn3rd Junior Member
    Middle Tennessee
    So I bought a non running as is used Prius. Other than bad battery Turns out it also has zero pressure on a fuel guage. I am using my hood HV battery for testing purposes. I Cobbled up some quick connectors and ran a test. It does have the fuel run out code but it will start up and I can hear the engine run but it stops after a couple seconds. I do I back probe the pump to see if it’s got juice?? I have found a lot of mice nests and want to make sure it’s getting power before I buy a tank.
    Thanks!
  2. dolj
    dolj Senior Member
    8,600
    4,363
    Wellington, New Zealand
    The car is not really starting. It only sounds like it is as the electric motor is spinning the engine at around 1,000 RPM and stopping when the engine does not fire. You will quickly delete the hybrid vehicle (HV) battery doing this, so get the problem fixed or have an HV battery charger on standby.
    It would seem like a logical thing to test. You could also just apply 12 V for a couple of seconds to the pump plug to see if it runs.
    You could then test the harness connector to see if 12 V was present with the car in IG-ON.
    #2 dolj, Nov 20, 2021
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Have you tried just adding 5 gallons of gas?
  4. GhostmanOn3rd
    Middle Tennessee
    I will add 5 gallons of gas when I get home.
    how do i put 12v to the pump?
  5. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
  6. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    The Ghostman seems to have ghosted us. I wonder if he got it running.
    Raytheeagle likes this.
  7. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    Hopefully so 'cause that's the only way you make it from 3rd to home(y).
    jerrymildred likes this.
  8. Marty2go
    Marty2go Junior Member
    40
    Ohio
    Four Touring
    My fuel pump would not work after runnning out of gas.
    Checked everything after putting 7 gal of gas in the tank, fuses, relays, throtle body, and a jumper 12volts on the fuel pump. at first i was not getting any fuel out of an unhooked fuel line but since i didnt want to change the tank I kept trying even reversed the poles. After at least a dozen trys with the jumper it started pumping gas. I think it was dry and just wouldnt prime the pump. What a life saver. Thank you God! Page 11 on the work up quoted shows where to connect the jumper to the pump.
  9. Marty2go
    40
    Ohio
    Four Touring
    An after thought, it probably would never have pumped gas since it had air in the lines with back pressure. When I unpluged the line it reduced the pressure and I could see the fuel coming out when it finally did.
