Fuel pump replacement
Discussion in 'Gen 3 Prius Main Forum' started by Apatel1101, Jul 15, 2019.
  1. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I need an opinion on how to go about this this. I have 10 prius with 285k miles. I replaced the engine at 280k. I wanted to know the specs if the fuel flow can be measured using dash command. I Am worried about the fuel filter because the car is kind of slow. I drive it in regular mode. I have brand new michelin energy. As far as i know ghe last owner didnt know anything about maintenance for egr and it was all the way full with carbon.
  2. BZzap!
    BZzap! Senior Member
    1,607
    877
    The best thing you could do, would be to have someone with access to a lab scope or high end scanner to check your fuel trims for abnormal readings. O2 sensors may be erratic along with a dirty MAF sensor. All these Control you fuel trims. Plugged catylitic converter is also a possibility. That goes hand in hand with your discription. In any event these all have to be diagnosed by a competent technician with the proper tools.
  3. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    In preventatively replaced the fuel pump on our sold 2010 at 199 k miles and found the filter to have plenty of sediment ;):
    So could it restrict fuel flow: sure:cool:
    But something that can be sorted (y).
    #3 Raytheeagle, Jul 16, 2019
  4. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    I have access to toyota tech stream just havent messed around enough to know the procedure on how to check.
  5. Apatel1101
    Apatel1101 Member
    160
    60
    Orland Park
    That sounds like i should take the tank out and clean it
  6. Raytheeagle
    11,251
    15,481
    2019 Prius Prime
    I’d just do the pump ;).
    Draining the tank would be involved and collecting the gas could be tricky:cool:.
    Good luck and keep us posted (y).
    Grit likes this.
  7. BZzap!
    1,607
    877
    Before you go to the hassle of replacing the fuel pump on a whim, it might be prudent to, at lease do a fuel pressure test. If the pump shows less than minimal specified pressure, then you have some proof. Verifying the problem first may save you a lot of time and money.
    Grit likes this.
