Fuel reserve at 0 miles DTE - some data
Discussion in 'Gen 5 Prius Fuel Economy & Prime EV Range' started by Will B, Feb 16, 2024.
  1. Will B
    Will B Active Member
    389
    343
    Denver
    2023 Prius Prime
    XSE Premium
    All:
    It's taken a bit with my Prime, but I finally had enough fill-ups to try and get an idea of how much fuel is in the tank when the car claims 0 miles DTE. I've heard many folk say it is around two gallons, so a bit surprised I'm coming up with only about a gallon. Attached (hopefully) is the data I've gathered and math/assumptions, is there something I'm not doing quite right?
    For each fill-up I noted the DTE number and gallons filled. The manual says the tank capacity is 10.6 gallons, so the gallons still left is just the the capacity minus the fill-up amount. I thought about trying to use the cars claimed miles remaining and tank capacity for MPG, but that ends up being circular reasoning as you have to assume how many gallons are left at 0 miles DTE again! :) So, while not ideal, I just assumed my average MPG of about 45MPG. I then simply took the DTE miles divided by MPG to subtract those gallons from gallons in the tank to get an estimate of gallons in the tank at 0 miles DTE.
    Fully understanding this is noisy data, I wanted to get a decent number of data points before doing the math. As you can see, most of this data was all around a long (5,200 mile) road trip late last year, I hardly use any fuel around town--exactly why I got (and love) the PPPXP--Pretty Prius Prime XP.
    (I haven't tried an attachment in while, so if it still doesn't work the easy way, I'll follow up with a post doing it the hard way)
    will
  2. KMO
    KMO Senior Member
    1,503
    383
    Finland
    2023 Prius Prime
    Who says that? The manual says the low fuel light comes on at around "6.0 L (1.7 gal., 1.4 Imp. gal.)". And that happens before 0 DTE. I'd say it's maybe around 50km (30 miles) DTE.
    So you might use maybe about 2.5 L (0.7 gal., 0.5 Imp. gal) from warning light to DTE 0 (assuming pessimistic 5.0L/100km).
    Which is consistent with your 1 gallon.
    #2 KMO, Feb 16, 2024
  3. Tideland Prius
    16,122
    Interesting that the fuel reserve is much smaller. I guess with a more efficient engine, Toyota can do that. It used to be 10 litres. Good to know.
  4. Will B
    389
    343
    Denver
    2023 Prius Prime
    XSE Premium
    @KMO: I thought I had read that somewhere in these forums, but I'm not very good at searching for stuff I'm specifically looking for.
    OK, if the math checks out at least as best it can be, I'll take that info a reasonably accurate then. I've been both a "fill it up at a half tank" person and a drive it until it says empty person too for many years in a row of each. With the Prime it makes it easier to be the latter, so still mulling it over.
    will
  5. fuzzy1
    10,139
    What? No guts to measure it directly by deliberately running to fuel starvation, for engineering tests and general curiosity, like another member did with his Gen1, Gen3, and first-gen Prime? ;)
    [WARNING] Running out of gas (Gen III) | PriusChat
    [WARNING] Running out of gas | PriusChat
    If you don't have the guts to run this test, well, neither did I, at least with the Prius. Though I did do it with my '14 Forester. (Actually, wimped out on the Forester, stopped for the last fuel before a stretch longer than the spare fuel can could cover, and it died after pulling up to a fuel pump as I reached for the fuel log book. Refill matched the datasheet to within rounding tolerance.) Such tests do require very careful selection of circumstances for good weather, very low traffic, and lack of any important schedule to be somewhere.
    Trollbait likes this.
  6. Preebee
    Preebee Senior Member
    848
    745
    Midwest
    2023 Prius
    I've run my LE down to zero and have never put in more than 9.8 gallons at fill-up. The LE has 1.5g in reserve at 0 DTE.
  7. Will B
    389
    343
    Denver
    2023 Prius Prime
    XSE Premium
    @fuzzy1: :) Nope, not that bold! At least not on purpose. To your point though, the huge assumption is that the tanks capacity is per the spec sheet. I'm suspicious of that too given that in my Gen1 Prius I've pushed my luck and put over 11 gallons into a tank that is claimed to be only 10.5 gallons. Only your suggested test truly measures EMPTY and not quite willing to go that far. I suspect there is reserve even above what they say the tank capacity is. I've seen some other posts here where Subaru and Jeep really mean it when they say 0 DTE and don't do all this reserve stuff Toyota does. The engineer in me likes that approach, but fully appreciate Toyota's reasoning too.
    @Preebee: That would be interesting if Toyota picks different reserve levels for different models (Maybe not trim levels, but possibly between the Prime/AWD and not). One of my data points came close to suggesting a 1.5 gallon reserve, but that was the most extreme measurement. Gathering data is easy so I'll continue doing it. Just with a lot of city driving, the speed of gathering data is pretty slow.
    For my Alaska trip in my Gen1 I was carrying around a Jerry can of fuel as a precaution, so I guess I could do the "real" test, but not that bold. BTW, even for an ICE car, range anxiety can still be a very real thing up in the far north where gas stations are easily if not mostly 200 miles apart. That Jerry can was good insurance. My wife and I actually drove to the Arctic Circle in my Gen1, it was an adventure.
    will
  8. Arles
    Arles New Member
    United States
    It's interesting to hear about your experience with your Gen1 Prius exceeding the listed tank capacity. This adds to the evidence that there might be some reserved fuel even beyond the official specifications.
  9. N79PT
    N79PT Junior Member
    37
    Sonoma County
    2024 Prius Prime
    SE
    On a recent highway trip in HV mode I ran my Prime SE 15 miles past zero and filled up with 9.776 gallons. Speed on the highway was a steady 80 mph and calculated mpg was 42.4. (Windy day and some was mountainous)
  10. purplePriii
    purplePriii Member
    149
    56
    My understanding with fuel reserves was that most manufacturer calculated about 50 km in reserve between fuel amount left and average consumption they estimated at the factory. So the low fuel light turns on around that moment.
