Fuel Savers
Discussion in 'Newbie Forum' started by dropkin, Oct 12, 2008.
  1. dropkin
    dropkin Junior Member
    New York
    OK, I suppose the answer is: "If there was something that saved gas for sure, then we'd all have one," but I'm going to ask anyway.
    I was searching around for Prius mods, and found the Hyper Gauss Atomizer Improve Hybrid Fuel Efficiency
    Is this a scam, or does it actually do something to improve MPG? It seems very non-invasive, so I'd be willing to go for it if someone has had some good results.
    Is there a different product I should look at?
    :confused:
  2. Zildjian
    Zildjian New Member
    25
    Bilbao, Basque Country, Spain
    I've always had the feeling this is a scam. If I am not wrong, that stuff is something you put before the admission on the fuel pipe and it "magnetize" in certain way the gasoline, isn't it?
    If it would be so easy to improve fuel consumption I think manufacturers would include it on every car from factory.
    Regards
  3. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
  4. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    IIRC, I've read something about this or a similar product on CleanMPG.com.
    Apparently, the purveyors would have us believe that as the fuel passes
    through the magnetic field, each molecule picks up a minute charge. As a
    result, when the fuel is atomized, all the molecules are charged alike and
    repel each other... Voila! Total and instantaneous atomization at the
    molecular level.
    IIRC, the folks at CleanMPG considered the claims to be unsubstantiated and
    were wholly unimpressed.
    Of all the electronic gizmos that claim to be able to increase FE/MPG, only
    three types have proven themselves: CanView, and similar computer
    derived data displayers/loggers (it/they are not at this time generally
    available); ScanGauge II, and similar data display units; and the Hymotion,
    and similar supplemental HV battery pack systems.
    And all the rest? 99.99% pure bunkery. They are one or more of: alleged,
    claimed, fictitious, or maybe fraudulent "Fuel Savers."
    There is in fact some real science behind this gizmo's claims. In the maritime
    transport of petroleum products, it has been found that product falling through
    the earth's magnetic field via a loading pipe (30, 50, 80 ft. at tmes) does in
    fact pick up a charge. Charged fuel molecules are possible. That's the known
    science.
    The rest of the story: If the pipe is metal and securely grounded, and there is
    minimal open area at the bottom of the pipe, this isn't a problem because the
    charge is continually bled off. On the other hand, if the pipe is plastic, the charge
    can collect in localized areas. When the collected charge is strong enough, it can
    arc through the thickness of the plastic. (I know you can see what's coming.) If the
    vapor within the tank is within its explosive limits, BOOM! And a formerly perfectly
    usable rectangular barge/ship is a wholly unusable cylinder, usually split open to boot.
    With any luck, no one was hurt.
    For some time now, such tanks are also filled with inert gas, usually "scrubbed"
    diesel/turbine/boiler exhaust, to essentially eliminate such occurances,
  5. rigormortis
    1,340
    26
    san jose, ca
    you forgot one device that actually does work to save fuel
    the off switch
    you can also save fuel by not buying anything and religiously watching the fuel economy screen and using the gas pedal
    little as possible and trying to get as much as mpg as possible
    reading all those pulse and glide posts costs nothing (except your internet bill!) and will give you more gas savings
    then any of that worthless crap they sell
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's a scam. It only works to atomize snake oil and blow it in your face, providing a distraction while the makers pick your pocket.
    Don't bother looking at these things.
    Tom
  7. dogfriend
    7,512
    1,185
    Carmichael, CA
    There you go again, dashing someone's dreams. Dreamkiller. ;)
  8. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    i think TOM is calling it as it is......................RIGORMORTIS said the right thing.....watch your gas pedal, watch the MFD screen and drive as economically as you can. i guess i should practice what i preach..............my mileage has been horrible lately. too much of a leadfoot. :(
  9. dogfriend
    7,512
    1,185
    Carmichael, CA
  10. qbee42
    18,058
    3,074
    Northern Michigan
    We get this type of post on a frequent basis. It's not hard to understand the phenomenon: people want this so badly that they are willing to dispense with reason and believe anything. It's the basis of almost all scams. Women want to look twenty again, so they buy magic creams and lotions. Men want to be irresistible to women, so they take "male enhancement" pills. Everyone wants to be rich, so get-rich-quick scams flourish. It's basic human nature.
    The problem with these mileage boosters is that there isn't any quick fix. There are ways to get better mileage and more efficient cars - the Prius is a rolling demonstration of that - but they all take years of development and huge amounts of capital. Conspiracy theories aside, there is no way a backyard tinkerer can compete with the engineering might of the big auto companies.
    The place where the small guy has an advantage is with entirely new and unique ideas; ones where the big companies are blinded by the status quo. These major paradigm shifts are not going to bolt onto your existing engine.
    It all comes down to the same simple common sense regarding investments: If it sounds too good to be true, it probably is.
    Tom
  11. qbee42
    18,058
    3,074
    Northern Michigan
    Yes, I'm such a wet blanket.
  12. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    The easiest things to do to save fuel are
    - check tire pressure
    - turn off A/C
    - go easy on the gas pedal
    Those gimmicks have been proved to be scam on mythbuster.
    One simple logic: If that device worked, automakers would have been all over it by now.
