Fuel smell at the tailpipe and increase of engine oil.
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Ohid, Mar 22, 2023.
  1. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    I am facing two issues of my Japanese Prius v 2015, odo: 105k km.
    Issue 1: I found fuel smell at tailpipe or behind my car when engine is on. No fuel smell in the cabin. Its increasing day by day. Last year the fuel smell was very little and only found when the car first start of the day. Mostly winter time it was profound but this year the smell is still found at tailpipe even at the evening when the car is started. My long fuel trim stayed at 6.25% when engine is on.
    Issue 2: My engine oil is increasing in volume in the winter. At summer, it was not noticed. After 4 months, nearly 300ml oil increased. I removed it and finally changed the oil.
    What is wrong with my car? Could you suggest the ways to fix these issues?
    Thanks in Advance.
  2. Mendel Leisk
    41,149
    Not sure of fix, but definitely want to change oil more frequently, till you find a fix. Google “gas in oil”.
    Tim Jones and Ohid like this.
    51,719
    is your fuel usage increasing?
    are you driving short distances with the engine unable to fully warm up?
    Tim Jones likes this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,426
    2,393
    Taylors, SC
    I would check the charcoal canister and the evap system including the evap valve.
  5. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Yes, I mostly drive for short distances. In the highway, fuel uses remain more or less same.
  6. bisco
    51,719
    From what I’ve read, short trips in colder weather can cause it
    Ohid likes this.
  7. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Here not much cold. Rearly temperature goes down below 12 degree centigrade, now temperature is 22-28 Degree centigrade.
  8. bisco
    51,719
    If it’s not that, it gets more complicated.
    How much is 300ml? If you started at the full mark on the dipstick, how much above it would that be?
    And after how many miles?
  9. Ohid
    Ohid Member
    157
    Dhaka, Bangladesh
    2015 Prius Alpha
    Actually my car has 4.2 L capacity. I poured 4L oil on it when changed old oil. Oil grew over full mark. nearly 2 mm over after full mark within 3.5 months drove only 1600 km.
  10. Mendel Leisk
    41,149
    Distance between dipstick marks is roughly 1.5”, and according to Owners Manual represents 1.5 liter.
  11. bisco
    51,719
