Fuel system failure epidemic
Discussion in 'Gen 3 Prius Main Forum' started by JohnHurt, Jan 19, 2018.
  1. JohnHurt
    JohnHurt New Member
    Claremont CA
    my daughter was driving our 2010 Prius with 174k miles on a main suburban Los Angeles street when she go warning sounds and lights when the car went into limp mode. She pulled off the street 50' from the entrance to our regular mechanic when it completely died and put itself in park with the brake engaged. All the dashboard warning lights were illuminated and it wouldn't start since the "ready" message didn't appear. Tried to disengage the brakes and shift out of park but nothing happened. Our trusted mechanic ran codes and got ECM failure, low engine performance and catalytic converter failure before the system stopped communicating with the code analyzer.
    The local dealer said that AAA should try jumping the auxiliary battery since that was the cause of the low engine performance code. They tried to jump the auxiliary battery without success and the car had to be dragged onto the flatbed since the brakes were locked.
    The dealer said that the batteries weren't dead but would need replacement but that the problem was due to a fuel system failure and that they had 7 (yes seven) in lined up for fuel system replacement but had to order parts after the MLK holiday. They said all the local parts had been used so the previous car required shipment from San Francisco so the source of our parts might be from out of state. The new complete fuel line and pump system was received and installed four days later at a cost of $930. The other cars were all 2010s so the coincidence of similar fuel system failure is very suspicious. The dealer said there was no recall except to the headlights failures for which the replacement switch is back ordered.
    Anyone else find similar failure patterns?
    49,448
    not that i've noticed. bad gas station maybe? any detail on exactly what is bad?
  3. BZzap!
    BZzap! Senior Member
    1,607
    877
    The fact that there are several vehicles in the same shop for the same thing would suggest to me that there may be a fuel contamination problem in your local area. It would be intesting to collect some data from the owners to see if there is some trend that may point a finger at the culprit.
    RRxing, Montgomery, m.wynn and 2 others like this.
  4. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Not far from and not so long ago, a gas station here fuel truck inadvertently dumped diesel in the premium reservoir and premium in the diesel reservoir. Cars that fueled up that day w/diesel or premium kaputted. Any publicity is good publicity, but not this one.
  5. padroo
    padroo Senior Member
    2,763
    2,250
    I always wondered how well the Prius fuel pumps were holding up. I never heard of a failure. If it was bad gas you would think other Toyota's and other brands would suffer a similar fate.
  6. BZzap!
    1,607
    877
    Who’s to say there aren’t other dealerships in the same area that are inundated with fuel system problems on their customers vehicles?
    scona likes this.
  7. m.wynn
    m.wynn Senior Member
    684
    1,226
    Queensbury, NY
    There have been aging Gen 3 fuel pump failures connected with P3190 documented here, but pretty isolated at this stage. So many at one dealer does seem odd...
    Raytheeagle likes this.
  8. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Interesting mystery.
    You'd think if it was contaminated fuel that the dealership or service center would be able to determine that as they replaced the systems. And you'd think they would share that information with the respective owners.
    If it's a intrinsic defect or weakness of the fuel system...I guess that will manifest as well.
    In either case it's an interesting mystery.
  9. wjtracy
    wjtracy Senior Member
    11,324
    3,591
    Northern VA (NoVA)
    As far as blaming fuel, I have never heard of a fuel that works well but kills the fuel system (except maybe ethanol). Diesel will normally kill the engine. So tentatively sounds like we are talking a car problem.
  10. Johnny Cakes
    Johnny Cakes Senior Member
    1,016
    764
    Virginia, USA
    What makes this mystery interesting is that a Google search reveals no other complaints of this type anywhere and then apparently many in a geographically small area (to the extent that Los Angeles can be so considered). Even by the OP's original message, Prius's as close as San Fran aren't experiencing this because that is where LA is getting parts from.
    Or maybe this has been hidden and kept secret for a long time and LA is at the forefront of the #MeToo-Fuel-Pump movement.
    kc5dlo likes this.
  11. m3pare
    m3pare Senior Member
    679
    1,818
    SoCal (626)
    My sisters 2011 also had the same issue a few months back around 172k. We’re in Los Angeles area as well. Fuel pump replacement at Hybrid Pit & all good to go.
    Montgomery likes this.
  12. bisco
    49,448
    pump and fuel lines? $900.?
  13. Montgomery
    Montgomery Senior Member
    2,254
    2,238
    Orange County, CA
    With 172k, one would wonder if there is any preventative maintenance that could be done at 150k?
  14. JohnHurt
    JohnHurt New Member
    Claremont CA
    Dealer said that there was no preventive maintenance possible and the failure happen without any warning-- often on freeways as was the case for three of the seven where the car suddenly stopped. At first they thought the catalytic converter might have become saturated with oil from a minor leak that couldn't be fixed and shut down the system but that wasn't the case.
    The actual cost was $928 including parts and labor plus tax.
    Regarding contaminated fuel she buys her gas mostly at Costco and the AQMD and county agencies that monitor fuel contamination would immediately investigate and shut down the station until the contamination was pumped out and tested. Also the high volume at Costco has ~ 3000 cars per day with multiple deliveries.
  15. bisco
    49,448
    that leaves us back at square one. maybe the dealers lips were moving.
    kc5dlo and Raytheeagle like this.
  16. wjtracy
    11,324
    3,591
    Northern VA (NoVA)
    ...Luscious Garage could probably shed some light...if someone goes over there ask
  17. m3pare
    679
    1,818
    SoCal (626)
    Unfortunately they don’t sell the pump separately... only as a whole unit which runs over $400.
    Sean and Roger at Hybrid Pit recommended to use top tier gas and to not run the car until almost empty. Other than that, not much maintenance you can do to prevent it.
    Ours also stopped on the freeway. Good thing speed of traffic was slow (morning) 20-25mph and my sister was safely able to move to the shoulder in limp mode/low power. Imagine you’re in the fast lane going 70-80mph (regular LA speeds) and the car suddenly loses power. :eek:
  18. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    I experienced the bad fuel problem causing most of the same damage you are reporting and repairs cost close to $1000.00. The Toyota 4runner drove normally until the failure, nothing was obvious. It took only 2 or 3 tanks to do the deed, hard to believe until you experience it.
    Unfortunately, it is difficult to connect fuel with the problem. So no one reports that the fuel is causing problems and the word does not spread to others who may have the same problem. My warning was also a Toyota dealer who happened to be near the gas station and thus experienced the same failures in a bunch of vehicles. And they managed to connect the problem with the spate of repairs that all happened within 2 or 3 days. The common denominator, of course, was the bad fuel from the refinery. The refinery, when faced with the truth, paid all the repair costs encountered. I am not saying that this is your problem, but it well might be.
  19. douglasjre
    douglasjre Senior Member
    1,875
    651
    Orlando, FL
    Italian Tune-up
  20. High Mileage
    High Mileage Active Member
    135
    231
    2018 Prius Prime
    John, I am not trying to split hairs here but I think its important to detail exactly what happened for your sake and others who may read this post later. I was a dealership or stealership mechanic whichever you wish to call us, for 16 years, and it was always very important for me to get exact or as close to exact details as to what was happening with a vehicle so I could properly diagnose a problem.
    To quote several statements: "She pulled off the street 50' from the entrance to our regular mechanic when it completely died and put itself in park with the brake engaged." I have never seen a 2010 prius put itself in park and apply the brake without the driver pushing the "P" button and the driver using their foot to mechanically apply the parking brake.
    "All the dashboard warning lights were illuminated and it wouldn't start since the "ready" message didn't appear. Tried to disengage the brakes and shift out of park but nothing happened. Our trusted mechanic ran codes and got ECM failure, low engine performance and catalytic converter failure before the system stopped communicating with the code analyzer." So if they were unable to get the ready message to appear then the vehicle will not shift out of park, but there should have been nothing prohibiting release of the parking brake.
    "The local dealer said that AAA should try jumping the auxiliary battery since that was the cause of the low engine performance code. They tried to jump the auxiliary battery without success and the car had to be dragged onto the flatbed since the brakes were locked." Again I do not get this. My assumption is that the 12V car battery was ran low due to use of the flashers or use of electrical systems while waiting for the tow truck. Once the tow arrived they were unable to get a "ready" light that would allow them to shift out of park, most likely due to a low 12V battery, or possibly even due to a low hybrid system battery.
    I can say I have 230K on my 2010 with no issues. In this case if there were truly 7 other 2010 model prius's for the same exact issue then it sounds like there may have been some issue with fuel supply that probably affected more than just the 7 prius's at that dealership.
    Again all I am trying to do here is to help you and someone else later. In your case it sounds like your daughter experienced a fuel pump failure. There have been no chronic issues of fuel pump failures on any of the prius generations that I am aware of. In you case with only 174K it seems like an early failure that could have been caused by some sort of fuel contamination. It is unfortunate that Toyota does not allow replacement of the fuel pump only. But they like just about every other manufacturer out there have "modularized" the pump assembly. In your case they used the term "fuel system" I think to describe the fuel pump module. I will say that Toyota was and is very smart in allowing access to the pump from below the rear passenger seat. In my days working for GM most pump replacements required removal of the fuel tank which brought the labor cost up substantially.
    CR94 and bisco like this.
