Fuel tank capacity
Discussion in 'Gen 2 Prius Main Forum' started by Caroline58, Mar 1, 2007.
  1. Caroline58
    Caroline58 New Member
    Hello everyone - I've had my new Prius a week and love it! But I hope someone can throw light on the fuel tank capacity.
    My manual and the Toyota UK website say that it has a capacity of 45 litres (or 9.9 UK gallons). The last pip on the fuel gauge began blinking yesterday and I drove another 15 miles maybe before stopping to fill up. Going by my mileage (about 425 miles) and mpg (45 to 50), I felt that I was cutting it a bit fine but should have a reasonable amount of fuel left. But I managed to fit 44.69 liters in the tank! How can I have been driving fast on a motorway with almost no petrol in the tank! Or does it really hold more than 45 litres?
  2. richard schumacher
    7,663
    1,038
    United States
    You can drive as fast as you want until you actually run out of fuel :_) As to how you got 44.7 litres into the tank, all of the planets must have been in alignment. Others have learnt the hard way that when the last pip starts to flash you really are about to run out, no matter how much you put in at the last fill or how far you have driven since.
  3. brick
    brick Active Member
    1,083
    78
    Upstate NY
    If you are in the UK, then supposedly you are in a completely different boat relative to us North American folk. Our fuel is contained within a flexible bladder, which changes size with temperature and age. As a result it's nearly impossible for us to accurately estimate our true maximum cruising range for any given tank full. But I **think** you just have a standard tank. There is still some variability there but it is much less than with the bladder.
    One possibility is that you were really on fumes. The other possibility is that your tank had been filled somewhat higher than the rated capacity. That is easily done in most cars by letting extra fuel flow into the filler neck. NOT recommended, mind you, but the capacity is there. It could be that this time the pump shut off later than it should have.
  4. Tideland Prius
    16,127
    not sure. Given that you don't have a fuel tank bladder, you should've pumped 35 or so litres (given that Toyota has a 10 litre reserve when the low fuel light comes on).
    It's possible that you either had a faulty fuel pump or you filled the fuel filler pipe too (but I doubt that could hold 10 extra litres).
    My advice is to check this tank and see if you could go farther than 425 miles, then you'll know if you had extra fuel in the tank.
    I remember pumping nearly 7 US gallons in a tank when I had 4 bars left. I carefully watched that tank and it turned out to be my record tank lol.
  5. ken1784
    ken1784 SuperMID designer
    2,940
    1,365
    67
    Yokohama, JAPAN
    <div class='quotetop'>QUOTE(Caroline58 @ Mar 1 2007, 10:17 PM) [snapback]398363[/snapback]</div>
    The tank specification of the Japanese Prius is the same, 45 liters.
    It does not have a bladder and it holds about 50 liters on the level ground.
    Our experience is it has about 6.5 liters when the last pip starts blinking.
    We saw about 60 liters pumped when rear left wheel was jacked up. :)
    Ken@Japan
