Fuel tank size
Discussion in 'Gen 3 Prius Main Forum' started by Niggtwish, Jul 21, 2021.
  1. Niggtwish
    Niggtwish New Member
    UK
    ----UK----
    Hi.
    I'm new around here, just bought a 2015 Prius (ZVW30) imported from Japan. I couldn't find in any of the documents the fuel tank capacity. Any idea?
    PS: I apologize if I posted in the wrong place.
    52,396
    congrats and welcome!
    should be around 12 us gallons
    all the best!
  3. rjparker
    rjparker Tu Humilde Sirviente
    10,531
    6,613
    Texas Hill Country
    It will show empty around 10.5 gallons.
  4. ASRDogman
    ASRDogman Senior Member
    7,830
    3,987
    Acording to my owners manual it is 11.9 us gallons.
    Grit and Johnny Cakes like this.
  5. Johnny Cakes
    Johnny Cakes Senior Member
    1,057
    785
    Virginia, USA
    And pretty much regardless of your driving style, you are guaranteed to get at least 50 more miles when the "Distance To Empty" says zero.
    ASRDogman likes this.
  6. ChapmanF
    18,558
    Although doing so when the chief financial officer is with you in the car may lead to considerably more trouble than either stopping for gas or running out of it.
  7. ASRDogman
    7,830
    3,987
    If you go by 45mpg, on average, you should be able to go 535.5 miles before being empty.
    Plus what's in the filler neck, and the fuel lines....
    I certainly would not want to test that though. I usually fill up at half a tank and sometimes when
    it's down to a quarter of a tank.
    Only twice did I let it go until the light started flashing, and I was only a few miles from the gas station.
  8. Mendel Leisk
    41,915
    Same tactic here. Helps that even that takes me a month or more.
  9. ASRDogman
    7,830
    3,987
    I fill up at the very least twice a week, usually 3 though.
    And I'm always passing the stations I fuel up at so it's not out of my way.
    I like to keep it as full as possible, just in case....
  10. Grit
    Grit Senior Member
    6,577
    4,228
    Wilkes Land
    i fill up once a week so DTE is around 500 + - 25 miles. My commute can do 650 to 700 miles on a full tank but never do full tank fill ups, got netflix to binge on.
