Fuel Tank
Discussion in 'Gen 2 Prius Fuel Economy' started by pat2762, Nov 19, 2007.
  1. pat2762
    pat2762 New Member
    I have had my Prius for 10 days now and have been averaging 50 mpg. So my math tells me with a 11.9 gal tank I should be able to run close to 600 miles per tank. Well I have filled up three times now and every time I am on Empty at 350 miles? I am only able to put in 7 gallons when I fill so the 50 mpg is accurate. Is my gauge not working correctly? Or is that just the way this tank bladder works?
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    No, you aren't the only one. That's the way it works with the U.S. version of the Prius. The manual states 11.9 gallons for the gross capacity of the tank. The usable capacity is closer to 10, and variation caused by the bladder inside the tank makes it hard to know exactly how much usable fuel you have. I usually put about 8.5 gallons in mine on each fill, but I try not to run it down too close to empty. It's just not worth pushing it if it's not necessary. If you want a lot more information, search on the term "guess gauge".
    Tom
    srellim234 likes this.
  3. pat2762
    pat2762 New Member
    <div class='quotetop'>QUOTE(qbee42 @ Nov 19 2007, 11:34 PM) [snapback]541784[/snapback]</div>
    I'm just jealous of these drivers who say they are getting 600 - 1000 miles per tank, and I can only get 350. Other then that I am loving the car.
  4. qbee42
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(pat2762 @ Nov 19 2007, 10:45 PM) [snapback]541788[/snapback]</div>
    At 50 mpg you can go 500 miles on a tank, but you might have to coast to the edge of the road when you run out. Some people are hyper-milers, and work very hard to get extremely high mileage. Others like to push a tank to its very limit. The ones getting 600 - 1000 miles on a tank are doing both. I don't see the merit in pushing a tank to its limit, but to each his own.
    Tom
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Buying a Prius in Minnesota in the winter has the distict advantage of feeling incredibly happen when temps start rising in the Spring! Of course the disadvantage is that it's a MN winter and your FE will be pretty poor thanks to the cold temps...add to that a car that's not yet broken in and a novice driver and you will struggle a bit. Hang in there, be patient and let's see if you're not a much happier camper come May!
  6. Tideland Prius
    16,142
    <div class='quotetop'>QUOTE(pat2762 @ Nov 19 2007, 07:45 PM) [snapback]541788[/snapback]</div>
    That's in the summer. Be patient! :)
  7. MikeSF
    MikeSF Member
    416
    San Francisco
    I had a similar issue the other day, got really cold here, well cold for San Francisco, went to CostCo, left the store and went to fill up since I only had 2 bars left, I had driven close to 400 miles at this point. I put gas in, and the thing maxes at about 2.7 gallons! Now I know I was hypermiling or anything. I tried a couple more re-adjustments and to put more gas in but nada, I attributed it to a cold bladder that wasn't stretching as it should.
    Now the kicker is my fuel gauge stayed at 2 bars! *Grrrrr* and did so for the next hundred + miles!
    There definitely is some squirrelly happenings that can occur with that bladder.
  8. bat4255
    bat4255 2017 Prius v #2 and 2008 Gen II #2
    656
    262
    Dodge Co. Wisconsin
    2017 Prius v wagon
    Very few accurate fuel gauges out there. I have learned to trust my trip odometer, (assuming the Prius has one) reseting it at ea. fill up. Once a reliable mpg can be established, I would go by the mileage.
    If the tank is a comfortable 10 gal usable, and your comfortable with 50 mpg, that would be 500 mile range, I would fill up @ 400 miles, and work it from there. This would give you a 2 gal reserve. In winter, I would figure closer to 40 mpg. At 10 gal is 400 miles, fill up @ 350, should give you at least a 50 miles reserve.
  9. icarus
    icarus Senior Member
    4,884
    976
    earth
  10. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    I don't like pushing it but I've been putting off a trip to the gas station with this virus shutdown. Today, for the first time ever, I actually saw the blinking last pip indicating running out of gas was imminent. Ten downhill miles later the car only took 9.179 gallons(US).
    The rubber bladder is very inconsistent. Looking at the ledger book I keep in the glove compartment I see I have put more fuel in the tank about a dozen times and, as I said, never had the blinking light before. The most it ever took was 10.004 gallons and it was still displaying two pips on the gauge.
    That's why I almost always try to fill it up when it's convenient once the gauge displays two pips left in the tank.
  11. dolj
    dolj Senior Member
    7,643
    3,858
    Wellington, New Zealand
    Nothing worse than inconsistent bladders! :whistle: :ROFLMAO: :LOL: :LOL:
