FuelEconomy.gov official ratings posted - 58 City/53 Hwy Prius Eco - 54 City / 50 Hwy for Prius
Discussion in 'Gen 4 Prius Main Forum' started by Paradox, Dec 18, 2015.
  1. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    And now the official EPA numbers are posted on the Fueleconomy.gov website
    54 City / 50 Highway with 52 Combined for Prius 2016 Toyota Prius
    58 City / 53 Highway with 56 Combined for Prius Eco 2016 Toyota Prius Eco
    And here's a chart showing Gen 1 through Gen 4 Prius including both the 2016 Prius and Prius Eco.
    Old 'original' fuel economy estimates compared to the 'new' fuel economy estimates for the Gen 1 and Gen 2 Prius (though model year 2007 - Starting 2008 the new method was used to attain fuel economy)
    The Inquisitor, iplug and bisco like this.
  2. Netcub
    Netcub Active Member
    344
    170
    Kentucky
    So you can save 1.04 per week, by buying a Prius Eco. :cautious:
  3. fotomoto
    fotomoto Senior Member
    5,602
    3,778
    So. Texas
    Either the EPA has a new, different way of measuring cabin size or the Gen4 has shrunk:
    49,371
    great numbers! (y) closing in on 2004. :p
  5. Sergiospl
    Sergiospl Senior Member
    3,938
    1,351
    28
    Measurements
    2016
    / 2015
    Front head room
    39.4 in. / 38.6 in.
    Front hip room
    53.4 in. / 52.7 in.
    Front leg room
    43.2 in. / 42.5 in.
    Front shoulder room
    55.0 in. /54.9 in.
    Rear hip Room
    51.9 in. /51.2 in.
    Rear head room
    37.4 in. /37.6 in.
    Rear leg room
    33.4 in. /36.0 in.
    Rear shoulder room
    53.0 in. /53.1 in.
    Width
    69.3 in. /68.7 in.
    Height
    58.1 in. /58.7 in.
    Length
    178.7 in. / 176.4 in.
    Wheel base
    106.3 in. / 106.3 in.
    Cargo capacity, all seats in place
    24.6 cu.ft. / 21.6 cu.ft.
    EPA interior volume
    117.7 cu.ft. / 115.3 cu.ft.
    Curb weight
    3075 lbs. / 3042 lbs.
    Ground clearance
    N/A / 5.3 in.
    Maximum cargo capacity
    N/A / 39.6 cu.ft.
    Grus likes this.
  6. iplug
    iplug Senior Member
    2,455
    1,703
    Rocklin, CA
    Once a few data junkies here get their Gen 4 and post their Gen 4 vs. Gen 3 mpg commute stats, we will get some apples-to-apples numbers and see if these EPA numbers are really overly conservative.
    Not sure if cargo/luggage space measuring methodology has changed. More room for the next PiP battery?
  7. bisco
    49,371
    nice numbers serge, thanks. i like the increased front head, leg and hip room.
    really, these numbers prove all the haters to be wrong. again.
    Felt and Sergiospl like this.
  8. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    Looks like EPA is using around $2/gal so $3000 fuel save is about right.
    We need Toyota to explain how they quote EPA cargo space for us. Acutally EPA is in error above, right? Eco has 27-ft3 by "EPA cargo volume."
    According to Japan spec, I think Gen4 has same cargo space as Gen3 (about 17-ft3). Removal of spare tire gives a notch more.
    Way back in 2010 (for Gen3) there was a change in USA Cargo Space method to the so-called "EPA Cargo Space" method, at that point Gen3 went from about 17-ft3 to 21.6-ft3. Basically EPA has given approval to quote inflated cargo volumes. In my cynical thinking, EPA did this to allow plug-ins to claim large cargo volume that does not exist in reality.
    Why Cargo Specs Can Stretch the Truth
    What is going on with cargo space measurements? - Acura MDX Forum : Acura MDX SUV Forums
    #8 wjtracy, Dec 18, 2015
  9. Sergiospl
    3,938
    1,351
    28
    2016 Prius /2016 Prius Eco / 2015 Prius
    24.6 cu.ft. / 27.4 cu.ft. /21.6 cu.ft.
    EPA interior volume
    117.7 cu.ft. /120.5 cu.ft. /115.3 cu.ft.
    Curb weight
    3075 lbs. /3010 lbs. /3042 lbs.
    http://edmu.in/1Qxu4iw
    bwilson4web and bisco like this.
  10. bisco
    49,371
    you're good, man.;)
  11. bwilson4web
    15,511
    You might send a note to @Prius Team and suggest they get the facts and data to the respective web curators.
    MDNHW11 likes this.
  12. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    So an eco would have to be driven 150,000 miles to make up the cost premium over the regular Prius 2. And that's assuming that you continue to use the ultra low rolling resistance tires which could cost more and/or wear out sooner.
    Bottom line: it is fun to boast about great mileage but it is not worth it to spend more to lower the already low fuel costs of the regular Prius unless you drive a huge number of miles per year.
    JeffHastings likes this.
  13. bwilson4web
    15,511
    How many miles do you have to drive to make up for 'leather', 'moon roof', or 'fancy audio'?
    Fuel efficiency is an option like tinted windows or 17" wheels . . . something I want to have as much as others might want car 'bling.' Get over it because I don't friggin' care:
    It is something I want.
    Rickyedger, MDNHW11, eric1234 and 3 others like this.
  14. KrPtNk
    KrPtNk Active Member
    323
    283
    Pacific Northwest
    Or the bottom line might be a concern for your total carbon emissions. It is more really than dollars and cents, isn't it?
  15. energyandair
    energyandair Active Member
    905
    339
    Victoria BC Canada
    On paper, it looks as though they have moved the rear seat forward, increasing cargo capacity slightly, decreasing passenger volume slightly, and reducing overall leg room (front plus rear) significantly. (43.2-42.5 + 33.4-36 = 0.7-2.6 = -1.9)
    OTOH, reports from tall people who've been in them are that overall leg room is fine so maybe seat configuration makes a difference or maybe the method of measurement has changed or maybe the 2015 figures reflect the driver's seat rather than the front passenger's seat.
  16. fotomoto
    5,602
    3,778
    So. Texas
    I normally agree with this philosophy and have used it with others who bring up the subject but in this case I think it is a valid comparison and will be made by many (most?) shoppers.
  17. bisco
    49,371
    i don't think most shoppers will be looking at the eco, and i don't think toyota cares. i do think it's phenomenal that toyota decided to offer it to a very likely limited market. if it helps them meet cafe standards or whatever, good on them.
    Felt likes this.
  18. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I understand why the ECO model 'exists' this go around and give Toyota props for offering it to those who appreciate it. But, with that being said IMO, the Eco model is completely for the 'numbers nut' who only cares about touting fuel economy numbers. For the average person, Prius will be the more shopped model, again, only in my opinion.
    Personally, and I know this has come up numerous times, I will not buy another vehicle that doesn't have a spare tire. I don't care about the goo pack that replaces the spare, it is useless. I also would not throw my own spare somewhere in the car, taking up space behind a seat or strapped down in the cargo area. This may not bother some but it would certainly me both functionally and aesthetically.
    Also, having gone through a blowout in my Volt, the whole pressing the button to have someone come and help/tow is useless and time wasted compared to just putting on a spare oneself. Everyone has varying opinions on this and of course that is completely understandable, but I am willing to bet once someone gets burned not having a spare, some but not all peoples opinions will change.
    Now, ALL that being said, it's something people will have to deal with during their purchase decisions as spare deletion is slowly beginning to affect not just EV and plug-in vehicles but hybrid and conventional cars as well.
  19. bisco
    49,371
    i agree with everything you say except buying a car without a spare. i can't let that stop me from buying the car i want, there are too many other things that are way more important to me. i have gotten used to the spare on the hatch floor, but would prefer it underneath.
    JeffHastings and Trollbait like this.
  20. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    well you can always get a compact spare like some PiP folks did. So the question is can you find a good place to put it. I like the small spares I wonder if someone will invent a plastic one or something nifty. Like those bed mattresses come springs compressed and then pop out when you need it,
