Full Battery & going downhill - Engine coming on?
Discussion in 'Prime Technical Discussion' started by SeattleHawaii, Jan 27, 2017.
  1. SeattleHawaii
    SeattleHawaii Member
    48
    57
    Seattle, Wa & Papaikou, Hi
    Hi folks - 2500 miles on my prime after over 2 months driving. Loving it 100% no complaints here! One question that I had...if the battery is 100% full and one goes downhill, hitting the brakes and hence filling the battery...I noticed today that my ICE turned on in two occasions...is that to be expected? I was in EV (not EV auto) mode.
    thanks much for any insights.
  2. mr88cet
    mr88cet Senior Member
    2,313
    1,335
    Austin, TX
    My guess would be that it's kicking in engine braking like "B" does on my Gen-2.
  3. SeattleHawaii
    48
    57
    that was my thinking...it doesn't do it always...I have a slight hill going down from my house when the car is fully charged and haven't noticed it yet. Today's hill was a bit steeper though...
  4. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Engine is on without burning fuel. Watch the display to see that no fuel is being used, then it's engine braking for sure.
  5. bisco
    52,376
    does it go through the whole warm up cycle?
  6. SeattleHawaii
    48
    57
    the display did stay in EV mode, meaning it showed the EV acceleration, however the range didn't go down driving and the mpg's changed from the usual 199.9 to a lower mpg showing that the engine obviously was on..went back to EV after a minute or so...
  7. bisco
    52,376
    a minute isn't full warm up, even in warm weather, so that's good.
  8. bisco
    52,376
    try ev auto and see what happens.
  9. 'LectroFuel
    'LectroFuel Senior Member
    880
    673
    San Juan Capistrano, CA
    How is the engine on without burning fuel?o_O:confused:
  10. 'LectroFuel
    880
    673
    I go down a large hill everyday and the battery gets full. It's normal. The battery doesn't want to overcharge and therefore doesn't want to use the regenerative brakes. When I stop at the bottom of the hill, the engine revs pretty high. There are probably better ways this could be done because I'm always thinking in my head "I'm wasting gas going downhill! There's no more room in the battery!"
    citiprius likes this.
  11. David Beale
    5,963
    1,989
    Edmonton Alberta
    The HSD spins the engine without injecting fuel. You have to be moving, of course, and above a minimum speed for this to happen. You can see you aren't burning fuel by mileage displayed, and if you have a "Scangauge" you can see the fuel being used "instantly" (with about a 1 sec. delay). The "normal" Prius does this to keep control when descending a hill with the battery "full", and you applying the brakes gently. "Full" meaning it doesn't want to charge the battery any further. Computers understand differently than we do. ;)
    'LectroFuel likes this.
  12. Captmiddy
    Captmiddy Active Member
    225
    204
    Massachusetts
    I had this happen yesterday, went down a hill and at the bottom the engine came on and it stayed on through the likely normal warmup cycle. It didn't go back to EV mode for 5 minutes. I did not have a full charge at the top of the hill, I was below 20 Mile range, but while the engine was on I started gaining range. It was almost like it was on charge mode. This same hill in the other direction causes the engine to come on going up so I am just going to consider this the Prime Curse Hill :D.
  13. bisco
    52,376
    yes, that was definitely the warm up cycle. o/p's description of one minute, and average mpg's going down might be something new toyota has come up with, or just an error.
    for anyone leaving there home and going downhill that fires the engine on a regular basis, the only solution on the pip was not to fill up the battery all the way when charging.
  14. Sam Spade
    Sam Spade Senior Member
    2,036
    1,023
    2017 Prius c
    You connect the engine to the wheels......and then don't feed it any (or just a tiny bit) gas.
    That is the definition of engine braking.
  15. SeattleHawaii
    48
    57
    hmm...maybe it was closer to 5 min....
  16. bisco
    52,376
    it's hard to remember if it's not something you're not concentrating on at the time.
  17. 'LectroFuel
    880
    673
    Oh, I never knew that the HSD could power the engine at such high RPMs, interesting. Why doesn't the regenerative braking stop "regenerating" when you take your foot off the gas and the battery is "full?"
  18. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    It does - it's using the engine's pumping losses to dissipate energy (turns the kinetic energy of the car into heat in the air).
  19. 'LectroFuel
    880
    673
    On my gen 2, the green arrows are going from the wheels to the electric motor to the battery when the battery is full, so I thought it was trying to charge the battery still. I just learned a lot about a car I've had for almost 12 years:LOL:. thanks!
  20. jdonalds
    jdonalds Active Member
    541
    225
    Redding, California USA
    That's normal behavior. Once you've used the motor-generator to fully charge the battery the extra regen energy has to go somewhere so Toyota kills the motor-generator by making the engine take the role.
