Full ipod integration?
Discussion in 'Gen 2 Prius Audio and Electronics' started by rleduc, Apr 4, 2008.
  1. rleduc
    rleduc The glass is always 1/2 full.
    Timmins, Ontario
    Hello All
    I know there are other threads on this forum that talk about this so if someone wants to point me in the right direction that would be much appreciated.
    My question is this: Is there an ipod kit that offers full touch screen control for an ipod? I have the premium package (in Canada there are only 3 options, base, premium, and nav). The premium here is the one with the jbl, vsc, backup camera, but not the nav)
    Is there also an option for video, eg from an ipod touch to the vehicle's information screen?
    Any advice, weblinks appreciated.
  2. aaf709
    3,862
    2022 Prius Prime
  3. rleduc
    Timmins, Ontario
    Thanks for the quick response and weblinks...much appreciated.
    The ipod touch compatibility of the soundlink looks especially attractive.
    Have you had any experience with any of these and if so, what is your experience with the touch screen control on the prius with regards to ipod control?
  4. aaf709
    3,862
    2022 Prius Prime
    I have a 2005 so your mileage may vary. :)
    I have the DICE, which I bought through the Prius Shop here at PriusChat. In fact I got the iPod because of the DICE (long story). Recently I upgraded to the DICE Silverline.
    The DICE works fine for me. I plug in the iPod and turn on the audio. I've set the DICE for the SAT mode. This allows me to use the tuning knob on the radio to quickly go through songs, playlists, artists and the like. The song title, artist and album is displayed on the MFD. I can also fast forward and reverse using the MFD. The radio controls on the steering wheel also work. The DICE also charges the iPod.
    Others have the VAIS and are happy with that. It costs more, but seems to be more stable with the 2006+ Prius. It also will charge the iPod, but I don't believe it has the ability to use the tuning knob on the radio for iPod control.
  5. beboyle
    beboyle Junior Member
    39
    Phoenix
    Actually the VAIS gives you fully integrated iPod control through the MFD and steering wheel controls.
  6. rleduc
    Timmins, Ontario
    Thanks beboyle
    That was the unit I was thinking of getting. I'll have to order it online and install locally because there is no local distributor.
    How tricky was installation, how good was the install manual, and anything in particular (re prius integration) I should watch out for?
  7. aaf709
    3,862
    2022 Prius Prime
    When I installed my DICE, I used the installation guide for the VAIS 100i, which can be seen at http://priuschat.com/forums/knowled...7-how-install-vais-aic-100i-ipod-adapter.html
    Basically you remove the bottom glove box and the trim to the right of the MFD. There's a white block of wires that you unscrew (but don't disconnect) to get it out of the way. The VAIS (or DICE) plugs into the radio right behind the tuning knob.
  8. dkafrissen
    dkafrissen Junior Member
    Maplewood, NJ
    What affect does all this Moding have on the Warranty?
    Also if I have the charger plugged into an iPod on the aux you get feed back, does this also happen with the Dice or VAIS?
  9. Arlene.s
    Arlene.s Junior Member
    Switzerland
    2023 Prius Prime
    I had my iPod adapter (I believe VAIS) installed at the dealer. It works fine, in CD Changer emulation. The only problem is that I can only see 6 playlists - or "CDs". I did a little work-around by arranging the playlists according to genre, and listening in "random" mode. Be sure to correct line level output on the iPod, and engage soundcheck. I also got new speakers and an amp. The only problem is now I hear how terrible the quality is of the average iTunes song.
  10. aaf709
    3,862
    2022 Prius Prime
    There should be no effect on the warranty. If you went to Toyota to have them install an XM or Sirius, they would plug it in to the same spot (both VAIS and DICE have an extra plug just in case you have a satellite radio).
    I don't get feedback with the iPod with the DICE and I doubt it would with the VAIS. I do get feedback if I have something (with a charger) plugged into the AUX input on the DICE (maybe with the VAIS' AUX as well). A ground loop isolator fixes that.
  11. priuseeker
    priuseeker New Member
    CA
    The Vais is getting rave reviews. I guess they have great customer service as well. I'm leaning toward a Vais myself...
  12. hybridcouple
    hybridcouple New Member
    We have a 2008 basic model Prius. Does anyone have experience with either DICE or VAIS ipod integration products for the 2008 basic?
  13. mrblaise
    mrblaise Go Lakers!!
    2,248
    525
    Southern California
    I have a 2008 Model 2 and love my Dice unit. It does everything I could ask for in a unit and is $100 less than the VAIS :)
  14. kjconrad
    kjconrad Junior Member
    66
    Phoenix, Az
    I was kinda leaning towards the VAIS because I swear I read a thread here where most people were bashing the Dice and raving about the VAIS. Now this thread everyone loves their Dice unit.
    Is there anywhere that has an unbiased look at both units comparing features and usability?
  15. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I haven't personally done a side by side comparison of the 2, but I have not heard any complaints since DICE came out with the DICE Silverline (the one the PC Shop carries).
    The only thing that I am aware that the DICE cannot do right now is charge the iPhone 3G (but they are coming out with an updated cable in the next couple of months).
  16. CCC712
    CCC712 New Member
    22
    Nashville, TN
    [moving this post]
  17. hybridcouple
    Thank you everyone. We'll order the DICE Silverline and let you know what happens.
  18. CCC712
    CCC712 New Member
    22
    Nashville, TN
    I'm trying to decide whether to go with DICE or VAIS myself and so far I've found a few main differences other than price:
    1. The DICE unit changes the order of the songs in your playlist. It re-orders them based on album or artist name so when you go to play a certain playlist it plays them alphabetically based on album/artist, not the order you put them in on iTunes. I don't think the VAIS does this.
    2. With VAIS you can change playlists from your steering wheel by holding down the MODE button (see aminorjourney's video). Can't do this with a DICE, have to use the MFD.
    3. DICE has an extra mode called SAT mode that displays the category name. So instead of just knowing that "disc 2" is playlists, it actually says "Playlist". In SAT mode you can also use the tuning knob to scroll through names of songs/playlists/artists/etc for faster searching.
    DICE and VAIS owners - please correct me if I'm wrong about any of this, I got this information from previous posts and talking to support reps at DICE and VAIS.
    I think if you don't care about having your playlist song order changed the DICE is a better deal for the money and the SAT mode is a nice feature. But if the song re-ordering would irritate you or if you want to able to change playlists from the steering wheel then VAIS is a better option.
  19. troycole
    troycole New Member
    We just bought a 2008 Prius - Canadian Base Model (single CD, no navigation)
    Like many others here, I'm trying to determine what the best option for iPod integration is, based on functionality, ease of installation and price.
    The Vais and the DICE seem to be the heavy favourites for full integaraton, but there are a couple of others that I've stumbled across in my research that don't seem to be mentioned here at all. Just wondering if anyne has any experience with
    Grom Audio - GROM iPod Adapter Direct Interface(GROM-I2-TOY)
    or
    Scosche - AXIPTA
    Also, any thoughts on the best options for simply adding an AUX jack, so you control the music via the iPod rather than through the factory stereo and steering wheel controls? My only question with this, is how would I access the AUX input as my stereo only has AM, FM, Disc, and Scan buttons?
    Thanks in advance.
    Troy
  20. reverai
    reverai New Member
    119
    Alexandria, VA
    There is a Toyota version of a an ipod connection which I saw on ebay that seems to work only with 2008 and 2009 Prius's. I buy one of these if can find if my single CD player has a "audio head unit to be satellite ready"....
    You may want to check it out too.
    Steve
