Full of surprises
Discussion in 'Gen 5 Prius Main Forum' started by Paul Gregory, May 2, 2025.
  1. Paul Gregory
    Paul Gregory Senior Member
    1,191
    316
    Alberta
    2024 Prius Prime
    XSE
    Today, I was parked, just enjoying some sun in my Prius, and I heard a sound like a siren, and a tinny voice that said, "Battery too low, turning off accessory" or something like that. It didn't come from the stereo system. It sounded like it came from a small speaker somewhere.
    I love that about my Prius Prime, always something new.
    Xse and PrimeDan like this.
  2. RandyPete
    RandyPete Active Member
    370
    150
    Santa Margarita, CA, USA
    2024 Prius Prime
    XSE
    Little alien beings always looking over your Prius.
  3. Paul Gregory
    1,191
    316
    Alberta
    2024 Prius Prime
    XSE
    I think it probably would have played through the audio system, were it turned on.
    But it was not, therefore it came through some sort of alternate sound source that sounded like a very small speaker.
  4. RandyPete
    370
    150
    2024 Prius Prime
    XSE
    Your Phone ?
  5. Paul Gregory
    1,191
    316
    Alberta
    2024 Prius Prime
    XSE
    I doubt it, but it happened so fast, who knows?
  6. bisco
    50,832
    were you in 'ready'?
    what accessories were on?
  7. Paul Gregory
    1,191
    316
    Alberta
    2024 Prius Prime
    XSE
    I had it in acc, the stereo off, but the navigation was on. I'm sure the rapid drain was from the 12V cooler in the back, which draws 2.7 amps. Anyhoo, the solution was simple; I put it in READY mode.
    #7 Paul Gregory, May 2, 2025
    Brian1954 likes this.
  8. daisy555
    daisy555 Senior Member
    1,614
    677
    CT
    This is reminding me to ask if anyone knows what the tiny square speaker looking thing is that is located on headliner above driver seat. Probably above passenger seat too.
  9. Paul Gregory
    1,191
    316
    Alberta
    2024 Prius Prime
    XSE
    That's more likely to be a microphone.
    PrimeDan and daisy555 like this.
  10. Hammersmith
    Hammersmith Senior Member
    1,894
    1,883
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The sound came from the passenger dash speaker. That speaker functions as a replacement of the old* dedicated system speaker that would be built into the gauge cluster somewhere. The wiring to that speaker goes from the JBL amp, through the telematics transceiver, and finally to the speaker itself. The telematics transceiver is connected to the body ECU through the canbus network.
    So the ECU saw the battery was getting low and sent a command to the telematics transceiver. The TT was able to send the audio notice directly to the speaker without involving the head unit or amp at all.
    The reason it didn't sound normal was because it was only coming from the one speaker(you're used to hearing audio from all speakers at the same time) and because it didn't have the full power of the amp behind it.
    *By old, I mean 10+ years ago. I don't know when they switched from a dedicated speaker to just using one of the audio speakers, but I'm sure it's been awhile.
    RandyPete and RX808 like this.
