full size spare for 4-touring?
Discussion in 'Gen 4 Prius Main Forum' started by texasdiver, Apr 17, 2018.
  1. texasdiver
    texasdiver Member
    68
    114
    Vancouver WA
    Four Touring
    A series of events led me to purchase a full size spare for my 4-touring yesterday. What happened was that I had patched one of my OEM tires on the road and then a few days later brought it into a local tire shop (Les Schwaub) to get my thread patch replace with a proper one. What they told me was that I had driven too far with it flat to get off the freeway and damaged the sidewall. I was skeptical but their policy was not to re-mount what they said was a damaged tire. Lacking a spare I had to actually purchase something from them to drive away. They didn't have any tires in stock in the 17" rim size that I thought would be a good match for the OEM Yokohama tires on the car. So what I ended up doing is buying a cheap 15" rim they had in the same bolt pattern and a cheap 15" Toyo tire for about $170 out the door. Essentially it is now my full-size spare and $50 cheaper than any other option they had in 17" tires.
    So now I have a new full size spare on the car and will be going to Costco to get a set of new tires. But what to do with the full size spare? Leave it in the garage or put it in the car to replace the crummy little compressor and patch kit. I know others have bought donut spares for these cars that lack spares. Now I'm actually thinking about how I might pull out the foam in the back and mount the full size spare back there and build storage space around it to store all my roadside tools and emergency gear that is now sitting in a crate in back. It will raise the cargo area up a couple of inches but free up all the space that is currently occupied by the big plastic tote that holds all my winter and emergency gear.
    Anyone else done this and have suggestions? I could buy a second donut spare but now that I have this full size tire I might as well see if there is any way to use it.
    RCO likes this.
  2. MichelleStone
    MichelleStone Senior Member
    549
    818
    Mariposa, CA
    I keep putting it off. That's what I do. I would like a compact spare but I don't want it to take up room in the back. The best solution would be to either cut a hole in the foam or purchase the foam inserts. But I keep putting it off.
    RCO and alanclarkeau like this.
  3. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    If you have room under the deck in the cargo to accommodate a full size spare, yes that would be the best solution. Having a Prime without that space, I am keeping a full size spare at home. My driving consist of within 20 miles from home 99% of time. If I have a flat on a road, I will just call home to have my family bring a spare to me. For a long trip, I was planning to carry the full-size spare in already small cargo if I am worried about flat, but so far I haven't done that.
    Since2002 likes this.
  4. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    It's not really practical to haul a full size spare around all the time. However that doesn't mean it can't be useful. How you would use it depends on whether you are in town or on a trip.
    In town - You would keep the full size spare stored in your garage or basement. If you get a flat you would attempt to patch it. If successful, then when you later go to get it permanently patched you would bring the full size spare with you in case you run into the same situation that you just did. However if you can't patch it you would call spouse, friend, Uber etc. to come get you so that you can go home and get your full size spare.
    Trip - A full size spare is really nice to have on a long trip, because if you get a flat in the middle of nowhere and are unable to patch it, you can be really stuck. Even a donut spare can be problematic depending on how far away from home you are when you get the flat, as having to drive on a donut for hundreds of miles of Interstate is not a great situation.
    Whenever you carry the full size spare be sure to lash it down securely as it would be a dangerous projectile in an accident.
    EDIT - Well Salamander_King beat me by two minutes so you can ignore my post :) Except for the last sentence which is important.
    RCO likes this.
  5. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    Maybe you could check with @booke02 - I seem to remember that his car came with a full size spare. Maybe he might be willing to take a photo of the spare-tyre compartment for you to emulate.
    Only thing is - the 17' without a donut has a lower floor than a 15" with donut - so you might have to change the floor?
    RCO likes this.
  6. booke02
    booke02 Active Member
    391
    415
    Israel
    IMG_20180503_154736.jpg IMG_20180503_154736.jpg IMG_20180503_154754.jpg Not sure if these photos help at all, but this is how my Prius was factory-configured with full-size spare. I think that the round piece that is sitting in the center of the spare is to provide support for the floor that sits over the top of it.
  7. alanclarkeau
    7,045
    7,593
    Thanks for that!!!!
    Looking at the rim and tyre - is it the same size as the alloy wheels on the car? It looks like it's a steel rim?
  8. booke02
    391
    415
    Israel
    I am embarrassed - it is just dirty. The spare is the same size as the the other 4 wheels. It is also alloy, not steel.
  9. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
  10. bisco
    52,375
    makes it tough to get in and out of the back.(n)
  11. alanclarkeau
    7,045
    7,593
    I wondered about one of these if I were to go long distance travelling into remote areas. But we don't have provision for a tow bar and I was told that it's not compliant for towing.
    When I had my first VW Microbus, I converted it for camping and hung the spare at the front - but that hasn't go a door in the way.
  12. David Beale
    David Beale Senior Member
    5,963
    1,989
    Edmonton Alberta
    Do note that the "D" ring tie-downs are in the hatch of the "hatchback Prius", even if you don't have a spare with your model. Be sure to use those if you decide to place a spare wheel/tyre in there. Don't want that spare flying around in the car in the event of an accident!
    RCO, Since2002 and alanclarkeau like this.
  13. kithmo
    kithmo Couch Potato
    2,404
    2,776
    47
    South Yorkshire, UK
    Gen 4 is the only UK Prius that is compliant for towing, towing capacity 725 kg (1598 lb) under vehicle specifications in the manual.
  14. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    When I looked a few days ago, they seem to have withdrawn that explicit compliance notice. I didn't car it down to verify, but the page in was on showed Max towing weight 'zero'.
  15. Mendel Leisk
    41,889
    Once in a while I'm driving with four rims with mounted tires in the back, loose, coming home from the tire shop. It does cross my mind that I better take it easy.
