Fully loaded plus speed makes bad mileage
Discussion in 'Gen 3 Prius Fuel Economy' started by Neohippy, Jan 1, 2017.
  1. Neohippy
    Neohippy Active Member
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    With several threads on how bad mileage can be at high speeds I wanted to do a true test. Recently I felt my Prius could get 42-44mpg at 85-90mph. I filled up with 4 people and the trunk fully loaded and hit Alligator allley from Miami. I stayed at a steady 85-90mph as you can see my average speed was 83mph. I was doing this speed from 1 miles after the gas station. So fully loaded at 90mph was 35mpg. No air conditioner and no heat.
    szgabor and Mendel Leisk like this.
  2. Mendel Leisk
    38,727
    Thanks for taking a bullet, that musta hurt. (y)
    Phatlife likes this.
  3. Neohippy
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    Dropped down to 80-85mpg and turned on the a/c. Mileage went up 4-5mpg
  4. Phatlife
    Phatlife Member
    107
    27
    New Jersey
    must be all down hill? if I go beyond 80 mph is get only 44 mpg
    SM-G935T ?
  5. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    What did you expect? You should try this with a similar 1.6L midsized sedan like a Corolla and you would be still VERY happy that you have a Prius. :)
  6. Neohippy
    220
    201
    Clearwater,Fl
    2013 Prius Plug-in
    I'm not complaining. I realize this is great mileage all things considered. My other cars get 17mpg at those speeds.
  7. szgabor
    993
    175
    Oceanside NY
    OK, maybe I misunderstood your intention :)
