Funny behavior of front passenger window.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by DrPepperholik, Jul 6, 2014.
  1. DrPepperholik
    DrPepperholik Active Member
    342
    108
    Spartanburg, South Carolina
    This evening on our way home from a visit with my sister I rolled down my husband's window, the front passenger one. He went to roll it up and it automatically rolled down when it got to the top. I tried from my side and it did the same thing. If we rolled it up slowly, not auto, it was fine. I've only had the car since the beginning of May so stuff like this shouldn't happen, right? Is this something that should be covered under warranty?
    Oh and I tried it again after we got home and I turned the car off then back on and it did it again. Any ideas I could try or just take it to the dealer?
    iPhone ?
    51,155
    probably a switch adjustment. shouldn't happen, but things happen. def. warranty. unfortunately, no one pays you for your time.
  3. DrPepperholik
    342
    108
    Okay. That's good to know. My sister's radio crapped out in her 2010 and they said it wasn't covered under warranty but then said it was because she bought certified used. They didn't save the DVDs for programming from her old one and didn't have any from the used unit they replaced it with so they had to order her some and are sending them to her, it's been a month. :-( I know with electronic components like that they'll try to say it isn't covered.
    iPhone ?
    51,155
    a 2010 wouldn't normally covered, i believe it's 3/36.
    dorunron likes this.
  5. DrPepperholik
    342
    108
    Because she bought certified used it was covered. That goes up to 100,000 and 10 years maybe. She got lucky and it was covered that way. She only had it a year when that happened.
    iPhone ?
  6. IanIanIanIan
    IanIanIanIan Member
    152
    56
    Royal County of Berkshire, UK.
    2013 Prius Plug-in
    Reset the window sensor. It is in the manual.
    Run the window down but holding your finger on the button and keep your finger on the button for four/five seconds after it hits bottom. Then run the window up and again keep holding the button after it hits top.
    Let us know if it works pleas.
    hybridbear likes this.
  7. DrPepperholik
    342
    108
    Excellent. I'll try this when I go to lunch in an hour.
  8. DrPepperholik
    342
    108
    I tried it and couldn't get it to reset. It wouldn't stay up long enough for me to hold the button to reset it. I took it to the dealer and they reset it and had me home in time to see my little boy before he fell asleep.
    iPhone ?
  9. bisco
    51,155
    alls well that ends well.;)
    acceleraptor and DrPepperholik like this.
