funny little elec-motor buzzing noise on and off
Discussion in 'Prime Main Forum (2017-2022)' started by The Big Sleaze, Feb 5, 2020.
  1. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    I notice it after about 30 miles of highway when I come to bridge toll slow down to parking lot crawl speed.
    sounds kinda like an automatic antenna, but shorter duration. keeps happening till I speed up (and can't hear).
    cycles about every 20-30 seconds, lasts about 2 seconds.
    What could it be? happens with HVAC on or off
  2. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    It's probably the brake booster. Pump the brakes a couple times while stopped/parked and that will probably trigger it.
    There's also a periodic soft beeping sound that I think comes from the HVAC. Can anyone explain what that is?
    Trollbait and FuelMiser like this.
  3. schja01
    schja01 One of very few in Chicagoland
    1,744
    1,162
    Chicagoland
    2018 Prius
    “Funny”?
    Funny “ha ha” or funny “strange“?
    Does it “amuuuuse” you?
    Sorry, I couldn’t help my self. Great movie.
  4. The Big Sleaze
    286
    63
    'frisco
    2020 Prius
    Two Eco
    Oh, I guess since the motor ain't running there is no vac, hence yet another elec. motor. Makes sense, only happens when I'm in bumper to bumper and poking the brakes frequently.
  5. FuelMiser
    FuelMiser Senior Member
    1,294
    884
    Monument, CO
    The brake pedal is given a vacuum assist to make the pedal easier to push (AKA power brakes). In traditional cars, vacuum is sucked of the intake manifold. But in modern cars, an electric vacuum pump provides the assist. Thus, every time you pump the brake pedal, the vacuum pump operates.
  6. Trollbait
    11,515
    It is actually a pump plus accumilator, that allows the pump to not need to run all the time. Though any engine with a throttle plate will also use that vacuum when available. Aside from full hybrids, diesels, and turbos, a car likely doesn't need this system.
  7. ChapmanF
    15,494
    There is no vacuum used in the Prius brake system. There is an electric pump that forces brake fluid into a high-pressure accumulator.
    If you want to count the vacuum downstream of the throttle making the engine hard to spin during engine braking, then yeah, there is that vacuum.
    jerrymildred likes this.
  8. jerrymildred
    jerrymildred Senior Member
    11,508
    14,109
    Tampa, FL
    Ya beat me to it! :)
  9. FuelMiser
    1,294
    884
    Monument, CO
    Okay, I stand corrected. The point is the brake assist is making the noise...
  10. m8547
    m8547 Senior Member
    931
    615
    Colorado
    2018 Prius Prime
    The 4runner has been using a similar system since 2003 (and it probably wasn't the first). I'm guessing the electric pump allows more brake pressure to be used for when it automatically applies the brakes for traction control, rather than a vacuum brake booster that might not be able to recharge as quickly.
    Tacomas from the same era used a vacuum brake booster.
  11. meeder
    meeder Active Member
    239
    161
    Doesburg, The Netherlands
    Traction control systems mostly use the ABS pump.
    There are multiple ways of operating. The electric system that Toyota uses is useful since the engine doesn't need to operate.
    Diesel engines and turbocharged petrol engines often use a camshaft driven vacuum pump to provide vacuum.
    Verstuurd vanaf mijn LYA-L09 met Tapatalk
    Trollbait likes this.
  12. ChapmanF
    15,494
    Hmm, well, we can say there is a brake assist pump, and it does make a funny little elec-motor buzzing noise on and off.
    So it certainly might be what's making the OP's noise.
    But when saying that's what is making the OP's noise, most of us aren't right there with the OP's car.
