Funny sound shortly after takeoff
Discussion in 'Prime Main Forum (2017-2022)' started by ppongi, Sep 2, 2017.
  1. ppongi
    ppongi Junior Member
    43
    Allen, Texas
    I am wondering to see if anyone else has this issue. I hear a funny sound, hard to explain but some kinda 'chirp' or 'clank' sound shortly after takeoff. It happens every time when I start and takeoff and I don't use the parking break by the footwell. Any ideas?
    52,371
    maybe your rotors are a little rusty, and sticking a bit when you brake to a stop. has it been humid?
  3. Washingtonian
    Washingtonian Senior Member
    726
    621
    Surely you jest, sir. You are asking a Texan "Has it been humid".
  4. Prodigyplace
    12,667
    11,828
    Central Virginia
    I wondered if there was something on the runway used for takeoff. :LOL:
    priuscatprimeguy and ppongi like this.
  5. Lee Jay
    Lee Jay Senior Member
    5,850
    4,036
    Westminster, Colorado
    If it's on a hill, it's this:
    You'll hear a small sound when the brake is automatically released by the car.
  6. ppongi
    43
    Allen, Texas
    Thanks for all the replys. This only happens for the first time I drive for the day and about 200 yards into driving. Weird.
  7. huskers
    huskers Senior Member
    2,546
    2,487
    Nebraska
    Record it sometime so you can play it next time you go in for service.
  8. bisco
    52,371
    that makes even more sense with rusty rotors.
  9. mdhare
    mdhare Member
    59
    33
    Madison, WI
    I can confirm that I experience the same thing that the original poster has reported. I often hear this sound after leaving the driveway while traveling uphill during a time period when the brakes are not in use. I also report it is a short, single chirp, only after first start and shortly after takeoff. Since it doesn't seem to be affecting the vehicle I have not taken any action such as taking it to the shop. It's hard to locate the sound but I always assumed it was a traction motor, but the pointer to hill control is an interesting theory
    ppongi likes this.
  10. bisco
    52,371
    when you are stopped, pressing the brake very hard engages hill control with a signifying beep. when you proceed, there are no more sounds.
  11. scm2000
    scm2000 Active Member
    164
    125
    I have an uncle who used to entertain us as kids while driving by using his visors as flaps for takeoff and landing. I think the prime visors are too small for effective use as flaps though ;)
    jerrymildred and Mendel Leisk like this.
  12. ppongi
    43
    Allen, Texas
    Thank you for sharing. Uphill or downhill does not make a difference for me. I geuss we are the only ones here with this issue.
  13. RRxing
    RRxing Senior Member
    2,554
    1,828
    NEPA
    Could it be...???
    Prodigyplace likes this.
  14. mdhare
    mdhare Member
    59
    33
    Madison, WI
    Ppongi, I'll pay a bit more attention to see if I hear it going downhill as well.
    Bisco, thanks for the additional info on hill control (hard press and beep). I think this rules out hill control for my scenario.
    Rrxing, unless that sound is mechanical (I presume it is electronic) I don't think so, although if I had to guess I hear the sound around 15mph.
    I will try to gather more data. Rotor idea is interesting, my mechanical brakes don't get much of a workout. I had my ev range up to 42.4 a week or so ago :)
  15. Since2002
    Since2002 Senior Lurker
    936
    1,098
    Duluth, GA
    Yes Prius visors are too small. We have complained for years about the lack of visor extensions, some people have jury rigged homemade versions. Visor extensions would make them more effective blocking the sun from the side windows. And it would also increase the surface area of the visors which would help with takeoff and landing :)
    #15 Since2002, Sep 4, 2017
  16. alexcue
    alexcue Active Member
    346
    311
    So Cal
    Bisco, my 2014 Prius did that, but the Prime doesn't. You don't have to do anything special to activate it. Just hit the brake and if it senses the hill it will hold like the old version did, and no beep.
  17. bisco
    52,371
    nice! toyota technology is really progressing.
  18. Prodigyplace
    12,667
    11,828
    Central Virginia
    Try it! You'll Like it! :D
  19. scm2000
    164
    125
    Back to the OP... I think I've noticed the sound.
    I don't usually start off in HV mode, so maybe why I didn't hear it before, or maybe because I have audio playing usually... but twice today starting off in HV mode: back out of the spot, speed up to parking lot speed and then I hear what could be described as a faint "chirp" coming from the driver's side rear area.
    After that.. stoping and starting again in traffic you don't hear it.
    This is on level ground.
    I get the impression it's an actuator of some sort... maybe it's adjusting the gas cap or something. (You notice the gas cap turn after you turn it to click?)
    I'm quite used to a Prius making strange sounds... It's doing things it needs to do...
  20. Pdog808
    Pdog808 Active Member
    434
    290
    Los Angeles
    2018 Prius Prime
    Any chance it could be the auto door lock feature? I understand it engages at about 12 MPH or so. Doesn't sound like a chirp to me but worth a shot. I always wondered what that noise was when I first got my Prime.
