furel air ratio
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by VegasAlien, Jul 28, 2015.
  1. VegasAlien
    VegasAlien Junior Member
    Las Vegas
    My mpg has deteriorated severely (51-43 mpg). I am using Torque with a ELM 327. I measured the fuel air ratio below 10 almost all the time, both the calculated and measured. this seems a little rich. Does any one know what the correct ratio should be?
  2. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Check your engine air filter? Including the tubes leading to it? Sometimes a rag or other things will get in there "somehow".
    49,434
    i don't know the number, but would cleaning the maf help?
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    Monitor the TAFR (Target Air Fuel Ratio) parameter. This will tell you what the computer calculated value is. Then monitor the AFL (Air Fuel Sensor) parameter and see if the sensor is able to reach the target value.
  5. JTM2955
    JTM2955 Active Member
    475
    185
    Cleaning the air flow sensor helped mine.
    LG-D851 ?
