Fuse Box Problem
Discussion in 'Gen 2 Prius Technical Discussion' started by Ali Kemal, Mar 6, 2025.
Tags:
  1. Ali Kemal
    Ali Kemal New Member
    Boston
    Hello, I have an issue with my 2009 Prius. The radio, interior lights, and clock display are not working, and the car won’t start without the key fob. It’s likely that one of the fuses is blown or there is an issue with the fuse box.
    Can you help me? How much would it cost to fix? Is it something I can do myself?
  2. Tombukt2
    Tombukt2 Senior Member
    13,405
    2,415
    Durham NC
    The car should never start without the key fob You mean without the key fob insert it into the slot next to the steering wheel? Does your remote or your fob have a silver Toyota logo on the back or black? If silver there should be a button under your steering wheel marked k e y is that so? All of the business having to slot the remote. It's not that serious of a problem You need to check your 12 volt battery connections and think of anything that's changed since this problem started happening think carefully.
