fuse for 2002 prius
Discussion in 'Gen 2 Prius Technical Discussion' started by jeannine, May 27, 2008.
  1. jeannine
    jeannine New Member
    california
    2002 Prius
    What fuse is for the instrument panel which shows gas mileage and bars? The instr. panel is blacked out and I believe it is a fuse. They all have letters on them. Most I can figure out, but not this one.
  2. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    If the owner's manual is available, it will tell you which fused line powers the display. Unfortunately I do not have that info here.
    Another possibility is that you inadvertently pushed the 'screen-off' button sequence. To undo that, you would press 'display' and then the onscreen 'screen transition' button. That's the way I remember. Someone with Prius-access please help out.
  3. jeannine
    jeannine New Member
    california
    2002 Prius
    Thanks for your assistance. I already tried the display button and it doesn't respond.
  4. Patrick Wong
    18,200
    6,471
    Hi Jeannine,
    Assuming that you are referring to the MFD (the touchscreen in the middle of the instrument panel), check the 10A ACC fuse and the 15A DOME fuse. These fuses also power the radio, so if the radio is working then those fuses are not the problem.
    Also check the 5A ECU-IG fuse.
  5. jeannine
    jeannine New Member
    california
    2002 Prius
    Thanks for the idea. The radio does work and the radio touch buttons show up momentarily and then go black. When I push the audio button the radio buttons appear along with the display on and off buttons, but they don't work either.
  6. Patrick Wong
    18,200
    6,471
    Hi Jeannine,
    It doesn't sound like the issue is a burnt out fuse since buttons appear on the MFD. I've attached a TSB that potentially might relate to your problem. If not, then I suggest you seek dealer help for your problem.
  7. Chuck41
    Chuck41 New Member
    38
    Midwest
    Patrick
    are the TSB's available to the general public ? if so how do i download them ?
    Thanks
    Chuck
  8. Patrick Wong
    18,200
    6,471
    Hi Chuck,
    Michelle Vadeboncoeur and I have maintained a reasonably complete list of TSBs on the Yahoo interest group, toyota-prius-sat1, in the group files. You must be a member of that group to access the files. PriusChat has a forum that contains some TSBs, but the forum structure does not allow easy and neat storage of the files.
    The official source for repair manuals, TSBs and other technical information is techinfo.toyota.com which is a subscription website.
  9. Patrick Wong
    18,200
    6,471
    Hi Jeannine,
    Another thought: if this were my car, I would try removing the wiring harness connectors to the MFD and reinstall. Perhaps an intermittent or dirty connection is causing your problem. If this is out of the question for you to do yourself, then let the dealer mechanic help you.
