Fuse replacement 2006
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by shoenfeld13, Nov 20, 2009.
  1. shoenfeld13
    shoenfeld13 New Member
    Boulder, CO
    I read the last thread on replacing the fuse for the power outlets but couldn't figure it out. Which fuse needs to be replaced? I looked at the fusebox under the hood and did not find anything that seems to apply. Any help?
    Thanks:confused:
  2. Patrick Wong
    18,200
    6,474
    There are two fuses which you need to check, and they are located in the fuse box which is near your left knee when you are sitting in the driver's seat.
    15A PWR OUTLET
    15A PWR OUTLET FR
    If both outlets don't have power, check the first fuse.
    If only the front outlet on the dash doesn't have power, check the second fuse.
  3. shoenfeld13
    Boulder, CO
    THANK YOU THANK YOU THANK YOU... I didn't get low enough to look up to see the fuse box. I never would have found it.
    Take care,
    Josh Shoenfeld
    Boulder, CO
