Fuse Replacement - Power Windows
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Jim Langley, Aug 4, 2014.
  1. Jim Langley
    Jim Langley New Member
    Littleton, CO
    My power windows (all 4) stopped working - I suspect a blown fuse but cannot find fuse box map in manual. Any suggestions on how to locate appropriate fuse in appropriate fuse box location. Have a 2007 Prius
  2. GKuma
    GKuma Junior Member
    45
    Castaic, California
    It's been awhile but I believe the fuse box is on the front passenger side, you may have to remove the glove box( lower) and should be on the right.
    Sorry, can't verify because my 07 is being used right now.
  3. Patrick Wong
    18,200
    6,493
    If all other electrical systems are working, try the 30A PWR fuse which is in the relay/fuse box under the instrument panel on the driver's side. This fuse is on the side of the box where all the electrical wiring harness connectors attach so the box may have to be removed for access.
