Fuse type used at interior fuse panel
Discussion in 'Prime Main Forum (2017-2022)' started by av8r, Aug 29, 2021.
  1. av8r
    av8r Junior Member
    23
    The communist state of NY
    I'm prepping for a radar detector and other gadgets install and wondered what type of fuses are used in the interior fuse box on the 2021 Prime?
    Thanks
  2. xliderider
    xliderider Senior Member
    8,056
    3,223
    Honolulu, HI
    Low profile mini ATT fuses.
    Use the proper fuse taps if you tap one of the circuits at the fuse box for power.
  3. xliderider
    8,056
    3,223
    Honolulu, HI
    FYI, once you use a fuse tap like the one above, you'll no longer be able to put the fusebox cover back on.
    I have mine in the glove box, just in case I need to refer to the fuse location diagram.
  4. av8r
    av8r Junior Member
    23
    Thanks for the info. I'm ordering a custom cable and they offer to send you a fuse tap as an option, but I'm more than likely going to use a blend mount pin tap and brag power from the auti-dim mirror. Just wanted to have both options available.
