fuse
Discussion in 'Gen 2 Prius Main Forum' started by Rondo, Aug 14, 2011.
  1. Rondo
    Rondo New Member
    michigan
    hello is there a fuse for the the coolant heat storage water pump? im new here so need a little help:confused:
  2. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,520
    38
    Santa Fe, NM
    Heh. This is one of those where I curse people. In the engine compartment fuse box, this is a 10A fuse labeled 1*. You have to refer to the footnote to discover that this works for rear fog lights for Japan/Aus/EU cars, or the CHS pump for North America.
    To open the fuse box, use your index finger to press on the release tab, located on the most forward end of the box, immediately behind the headlight.
    There is also a relay, in the relay box mounted to the cowl above the engine.
    gdanner and Rokeby like this.
