Fusible Link
Discussion in 'Gen 2 Prius Technical Discussion' started by Jackie V, Nov 14, 2020.
  1. Jackie V
    Jackie V Junior Member
    Cincinnati, Ohio
    Thanks for the fine info about the blown fusible link. I am replacing it soon.
    *Question, do I need to unplug the hybrid or is disconnecting the 12v battery
    enough for safe extraction and installation?
    " Politicians and diapers must be changed often, and for the same reason.” ― Mark Twain
  2. ChapmanF
    18,569
    Disconnecting the 12 volt battery is enough.
    Jackie V likes this.
  3. Jackie V
    Cincinnati, Ohio
    Thanks, I'm wearing the rubber gloves-probably.
    "Good friends, good books, and a sleepy conscience: this is the ideal life."
    ― Mark Twain
  4. ChapmanF
    18,569
    Twelve volts won't bite you, gloves or no gloves. (If you apply it directly to your tongue, you'll taste stuff ... different stuff, depending on where you apply it. But tongues really only do sweet/salty/sour/bitter, all the other details come from noses, so the fun wears off pretty quickly. Heard from a friend.)
    The gloves are more for that 200+ volt traction battery and the distinctive orange wiring connected to it. You shouldn't need to be messing with that.
    The serious concern working around the 12 volt system is to avoid bridging it with your metal tools (or jewelry). That could lead to burns from something you're holding or wearing. Sometimes people will wrap sockets or other tools in electrical tape to make that less likely.
    In a Gen 2, you have two simple plug-in connections back at the positive battery post, a fat one and a skinny one. You just squeeze the latch on each one and pull it out. No tools, no drama, you're all disconnected and can just go to work on the fusebox or wherever.
