G3 Wire Harness
Discussion in 'Gen 3 Prius Accessories and Modifications' started by AzusaPrius, Jul 6, 2024 at 5:15 PM.
  1. AzusaPrius
    AzusaPrius Senior Member
    1,847
    811
    Get the new G3 wire harness, comes with bus bars and nuts.
    Better than OEM and will provide a better connection to your HV battery.
    Only at AcenBay.com and get 10% off with promo code "azusa"
    Stay tuned for my installation pictures Screenshot_2024-07-06-13-41-10-1.jpeg Screenshot_2024-07-06-13-41-38-1.jpeg Screenshot_2024-07-06-13-41-47-1.jpeg Screenshot_2024-07-06-13-41-56-1.jpeg Screenshot_2024-07-06-13-42-24-1.jpeg Screenshot_2024-07-06-13-42-33-1.jpeg Screenshot_2024-07-06-13-43-15-1.jpeg
  2. ChapmanF
    15,490
    I'm not always this enthusiastic about a product Azusa promotes, but I totally agree this one fills a genuine need, because Toyota would sell you one of these for gen 1 or gen 2, but they stopped selling it for gen 3 and just said "if you need it, buy a whole battery".
    The nickel-plated bus bars and wide SS flange nuts all seem well chosen. Nice package.
    There are a few bits on the sell page that do seem pretty superfluous:
    • To be as efficient or more efficient than OEM in transmitting a signal between the battery modules and the ECU.
    • Voltage sensor tabs are made of a better conductive copper alloy compared to the OEM
    • Wires' operational temperature rating is greater and internal resistance is lower, compared to the OEM.
    ... these wires connect blocks in the battery to voltmeter circuits in the smart unit. Voltmeters by nature are high impedance. Milliohms added or subtracted in these wires won't rise to the level of rounding error.
    I am glad the listing mentions the color code doesn't match factory. Even better if some label on the harness itself says that, just so no tech ends up looking at it and getting confused.
    Some information I would like to see and don't see would be the actual type of wire insulation used. Although this harness looks innocent enough, it is a high-voltage part, with wires that can be more than 240 volts different crowded together in a tight space (especially where they are bundled through the orange tubing). And the wires are very thin, which I suspect Toyota gets away with by using a very thin insulation that nevertheless has the requisite high-voltage performance. Similar thin wires commonly available for purchase might not have a suitable rating on this score—which is arguably more relevant than, say, higher copper conductivity.
