Gained 3 MPGs after fillup, thinking there's something up with the gas
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Feb 2, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    I always fill up at the same Shell station on a busy corner near the highway. Big station with 9 pump bays. Car's been showing 52.x for a couple tanks, and I haven't seen the 55.x numbers since about September or October. After fillup 3 days ago, noticed a few mpg increase. Same temperature, same conditions, CONS gage showing 55.x
    Seems to me gas quality not consistent. Did I get less ethanol with this tank? Don't know but skeptical of this station.
  2. El Dobro
    El Dobro A Member
    6,979
    3,214
    Could be a different supplier or another configuration in additives. Count your blessings if the mileage went up. :D
  3. jhinsc
    jhinsc Senior Member
    1,167
    259
    South Carolina
    I've always wondered if I used 100% gas (no ethanol) if my mileage would go up. I have a Shell station close by that sells it, but it's about $1 higher than reg. gas. Doesn't seem worth for 2-3 mpg more.
  4. El Dobro
    El Dobro A Member
    6,979
    3,214
    We don't even get the choice here, it's all 10% ethanol.
  5. Former Member 68813
    3,524
    981
    US
    One thing I noticed that if one day I get worse MPG, lets say 50 MPG, next day it's going to get better, say 60 MPG, delivering the expected 55 MPG average on the MPG indicator. Same commuting routine mind you.
  6. John H
    John H Senior Member
    2,208
    558
    I have given up on monitoring mpg, or even m/kWh.
    I have started just monitoring the actual fuel usage per commute trip, in each direction, using torque.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    You are just monitoring zeros then. You don't use any fuel. :p
    John Hatchett likes this.
  8. John H
    2,208
    558
    I was driving the Prius over winter break while my son drove "his" Volt. I followed another Prius to a gas station. :)
    F8L likes this.
  9. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    3 miles difference at 55 miles per gallon is some 5% difference. That's a small amount of gas. The error in your calculations could be that much. Even different pumps at the same station could give off that much error. Temps in northern ca were a few degrees warmer the past week.
  10. cycledrum
    cycledrum PSOCSOASP
    8,245
    1,202
    NorCal
    Ok, I would need to log conditions to really know what's going on.
    I was able to go from 54.4 back up to 55.1 in about a 1.x mile stretch coming home with no traffic behind and 100 miles into the tank. Short trips can chew 1 mpg off the gage pretty quickly, this car can EV pretty well in mid 30 miles per hour, or can drive it with just a hint of gas engine running up slight grades in 35 mph range.
    HSD works incredibly well. Great to see what Toyota is doing in new cars like 2013 Avalon Hybrid.
    ... Can hardly wait to see 4th Gen Prius. Given what they're doing with Camry and Avalon hybrids, new Prius should be much more robust, I hope. :)
  11. xliderider
    xliderider Senior Member
    7,872
    3,116
    Honolulu, HI
    I noticed something similar last summer, where the mpg in both of our cars dropped by about 4 mpg at around the same time.
    A drop in one car is one thing, but a drop in both cars during the same period, using gas from the same company/location is pretty strong evidence I would say.
    Both cars were monitored on Fuelly.
  12. mmmodem
    2,732
    1,703
    Bay Area, CA
    Strong evidence for sure. But you'd need additional data points to be conclusive. What was the fuel economy for the next tank?
  13. xliderider
    7,872
    3,116
    Honolulu, HI
    [​IMG] [​IMG]
    Direct links to the mpg info on Fuelly: Camry, Prius
    OK, now that I look at the graphs for mpg for both cars side by side, the mileage drop was not at the same time, and the drop was 3 mpg not 4 mpg.
    However, it is interesting that both vehicles showed a pretty noticeable drop in mpg followed by a recovery to average mpg. The graphs are eerily similar, the difference in time might be due to the fact that the Prius is fueled half as often as the Camry, so the drop in mpg shows up later for the Prius.
  14. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    Another thing to keep in mind is that the pump can shut off at a different spot from time to time. My old 95 Neon was all over the place on high way mpg and when the evac system messed up and I bypassed it...only allowing it to be filled up at a VERY slow pace...now every fill up goes to where it is near the top and I can hear it getting ready to pour out, but then it will click off. At 55 mph I always get 46 mpg, 60 mph it drops to 42-43 and 40 at 65. All those speeds are when I am slip streaming off of semis...at a SAFE distance.
  15. cosgrove
    cosgrove Junior Member
    44
    Los Alamos, NM
    Yeah, quality (energy content) of gasoline can definitely vary from place to place at the same time of year.
    Early last fall on a trip from Dallas to Santa Fe NM we filled up twice, averaged a terrible 43-45 mpg (real miles divided by real gallons). The gasoline back here in good old NM gave us our usual 50-52 mpg until cold weather set in. Same brand (Shell) both places and same time of year - has to be different fuel quality.
  16. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Don't you guys have different summer and winter gas there? We do in California, when switched to winter blend we gain power so MPG goes up.
