gapping spark plugs- required?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ericspoor, Jan 5, 2019.
  1. ericspoor
    ericspoor Member
    76
    37
    austin
    i changed the spark plugs with oem denso plugs, but i didn't occur to me that they might need to get gapped first. does anyone know if the oem plugs are pre-gapped?
  2. SFO
    SFO Senior Member
    5,302
    4,250
    Northern California
    Yes.
    Which plugs did you purchase?
    Raytheeagle likes this.
  3. ericspoor
    ericspoor Member
    76
    37
    austin
    to be honest i cant remember. they were denso brand. autozone's program indicated they were the oem plug, which may or may not have been accurate.
  4. Mendel Leisk
    42,093
    Most if not all plugs come pre-gapped, and especially with the high-end long-life ones, the plug manufacturer often will have a warning against adjusting the gap. The auto manufacturer spec's a plug, and will invariably list the gap that plugs come with, as the correct gap.
    That said, it doesn't hurt to check the gap. That's been the case with the last few cars we've had, and when checking new plugs I've never seen incorrect gaps.
  5. ericspoor
    ericspoor Member
    76
    37
    austin
    Thanks for the info! a follow up: does the coil pack boot require dielectric grease? that was another step i didn't take and only read later that it is a good idea to do.
  6. Mendel Leisk
    42,093
    Some swear by it. When I'm not sure, I consider the current condition. They didn't apply any grease at the factory, and it's been ok so far.
  7. brdmb
    brdmb Junior Member
    17
    Ohio
    Yeah, if they're platinum no need to gap - they're pre-gapped properly. I've never used grease on my Toyotas' boots/coils and have yet to have a problem
  8. Brando714
    Brando714 Member
    101
    16
    Anaheim, CA
    PLEASE READ! Wanted to give you guys a heads up on those spark plug gap gauge that I just noticed today before installing my plugs. I purchased mine from Autozone and the gap of the plugs straight from the box were off by a lot so I was kinda stressing out about having to adjust it then I noticed, there's a barcode sticker right where the ground electrode and the center electrode runs along on the gauge. This not only gave the false reading but also upon pealing the sticker, left an adhesive and you def don't want that touching your copper core or anywhere else for that matter so just be careful. Hope you guys read this and keep that in mind from my experience of what could've been.
  9. dolj
    dolj Senior Member
    8,619
    4,375
    Wellington, New Zealand
    If they're iridium (and the correct part number) no need to gap - they're pre-gapped properly. In fact, the iridium tips should not be touched with feeler gauges, as they can be damaged.
    jerrymildred likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,517
    14,164
    Tampa, FL
    I knew about not gapping them, but did not know this! :eek:
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,836
    Clearwater, Florida
    Op multiple post on same subject.
