Gas and Electricity Consumption - any Sites like Fuelly for That?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by cycledrum, Feb 29, 2012.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Fuelly | Share and Compare Your MPG is a great site for posting and comparing gasoline consumption among many different cars. Doesn't seem to be any way to post electricity consumption.
    There's 4 Volt owners with MPG data on fuelly, half the story.
    Is it feasbile and easy to determine electricity consumption into your PHV or EREV for a given tank of gas?
    Is there a site to post this info instead of getting buried in threads?
  2. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    The CleanMPG* mileage logs allow entry of kWh as well as gallons for each tank and it will show total kWh. but the listed mpg is just for fuel. * Disclosure: I'm a mod there.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    Don't know if it's useful for you but my UK electricity supplier provides a useful website to enable you to track your electricity and natural gas usage. You could use two options for electricity - one for the house, one for the car.
    I don't think there is an option not to allow you to set up an account.
    EBICO iMeasure - a buildings energy monitoring calculator
  4. ryogajyc
    ryogajyc Active Member
    985
    165
    Reseda, CA
  5. Rebound
    Rebound Senior Member
    3,994
    2,642
    Portland, OR
    Does the PiP measure kwh per gas tank? I don't even know how I'd track it, because I refill gas at different times from when I charge. But I suppose that, if I can reset the meter when I fill up, and if it's accurate, then it will work.
  6. ryogajyc
    985
    165
    Reseda, CA
    Like you said, you can use one of the Trip A/B meters. The one issue I see with that is that I think it measures kWh used from the battery. I think the more relevant kWh measurement is from the wall.
    Anyhow, I don't think that logging kWh necessarily has to be tied to logging gas tanks. They could be logged independently and combined afterwards in a MPGe calculation.
  7. GasperG
    GasperG Senior Member
    1,169
    601
    Slovenia
    2018 Prius
  8. ryogajyc
    985
    165
    Reseda, CA
  9. drinnovation
    drinnovation EREV for EVER!
    2,027
    586
    65
    CO
