Gas Cap Check Engine Light
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by nhanthanhto, Mar 10, 2017.
  1. nhanthanhto
    nhanthanhto Junior Member
    2015 Prius c
    TLDR: Gas cap was loose, check engine light came on, 300 miles later still not going away, what should i do?
    Hey guys I got a 2015 Prius C One that I forgot to tighten the gas cap all the way last time I fueled, so naturally check engine light came on.
    Checked it, tightened it, cap didn't look damaged so I figured I'd just continue on with my day. 300 miles later, my CEL light is still on and when I asked local auto store about it they said I needed a new gas cap.
    I've read things saying how I could just clear it with an OBD2 tool, but local stores won't let me do that (I'm borrowing theirs), or how it'll just go away on its own after a few tanks of gas.
    Any thoughts? (I know next to nothing about cars)
  2. jerrymildred
    jerrymildred Senior Member
    11,511
    14,113
    Tampa, FL
    Welcome to PC! I wonder if it would work to disconnect your 12V battery ground wire for a minute. That will clear most any code. If the problem is still there, the code will come back before long. But, it will also clear all you radio presets and any other changes you've made from the default settings.
  3. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    2015? I'd let the dealer handle it. Is it still under warranty?
  4. fuzzy1
    10,170
    How many ignition On-Off cycles have occurred since tightening? Some of these temporary CEL indications are tied to power cycles, not miles or time.
    #4 fuzzy1, Mar 10, 2017
    Raytheeagle likes this.
  5. ChapmanF
    15,622
    One thing you need to know is, there can be lots of reasons for the check engine light to come on. They all have different codes so you can tell them apart. A loose gas cap is one possible cause, so if the light came on and you decided the cap wasn't totally tight, sure, you may assume the two things were related, but until you read out the code, that is only an assumption. The ECU may have detected some other issue at around the same time, and at this point, you've put on 300 more miles without looking into what it is.
    So, never mind about using a code reader to clear the code. Start by using a code reader to read the code!
    If you get one of the codes for an evaporative-emissions leak, and you're sure it was the loose cap, then sure, clear the code, see if it comes back. If it does, you might have another leak to track down.
    If it comes back any other of the possible engine trouble codes, then you just need to fix whatever problem it indicates (or have it fixed).
    -Chap
    burrito likes this.
  6. nhanthanhto
    2015 Prius c
    Hey guys thanks for all your suggestions, so as it turns out all it needed was a new tank of gas to fix the CEL
    @jerrymildred i'll definitely keep that tip in mind, thanks
    @fuzzy1 toyota wanted to charge me 100 for a diagnostic before anything else, just like pepboys
    @ChapmanF yeah i got a code reader to read the code from autozone but they wouldn't clear it for me, kept on stating that i'd have to a. get a diagnostic and b. get a new duralast gas cap
    Thanks all for the help though!
    jerrymildred likes this.
  7. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    For anyone searching for this -
    The EVAP code takes a lot of drive cycles to reset and only in very specific conditions, such as the tank being more than 1/4 but less than 3/4 full for the test to even run.
    Options
    1 - drive normally for two or three tanks. Check Engine Light should go away on its own.
    2 - disconnect the 12v battery under the passenger rear seat for 10 minutes. This also resets all your instrument settings, radio, and sets all your car's emissions monitors to "not ready" for a while, but the check engine light will be off.
    3 - get an OBD-II scan tool and read and erase the code yourself. This also sets the emissions monitors to not ready but leaves your car's settings intact.
    If you are in a state where has to pass emissions - Don't do option 2 or 3 before your test is due. Those monitors need to all be ready to be able to take the emissions test.
  8. Mendel Leisk
    38,728
    If you do battery disconnect and then drive for say a couple of weeks, that should be ok too: it get's back to normal, would pass inspections ok?
  9. TheTimob
    TheTimob Member
    120
    79
    Divide, CO
    I think it'll probably be okay. I was an emission inspector in Pennsylvania, and while I did emissions monitor diagnostics on a LOT of different cars - but I never even saw a Prius with a check engine light or any emissions problem.
    Most emissions tests allow ONE monitor to be "not ready" as long as the check engine light is off. It's almost always invariably the EVAP test. This is one reason that most states that do emissions tests also pressure test the gas cap.
    Many of the monitors will turn to "ready" on the very first drive within 5 minutes. The oxygen sensor monitors, the catalytic converter monitor and EVAP monitor are the long ones.
    Fuel vapors are actually the biggest contributor to smog - more than what the car is burning. That's why the emissions systems are so focused on the gas cap problem. That's also why they always say to fill up at night or evening when it's cooler than in the middle of a hot day. Although California's gas pumps (and a few other states) have special gas pump nozzles that help reduce the amount of fuel vapors.
    #9 TheTimob, Mar 15, 2017
    burrito and Mendel Leisk like this.
  10. jdualan
    jdualan Junior Member
    South San Francisco CA
    I have a 2014 prius and codes P0441 P0455 and P0171 came on...added an oil can catch a few months ago and thought this could be the issue..symptoms are idling goes up and down...google says it might be a gas cap or purge valve issue..replaced gas cap first, cleared codes and symptoms went away..all good now..now i have spare purge valve in stock
