Gas clicks off before it’s full
Discussion in 'Gen 3 Prius Main Forum' started by BradC, Jan 7, 2020.
  1. BradC
    BradC Member
    42
    25
    Both of my 2014 cars do this odd thing where sometimes the gas clicks off before it’s full. When that happens, it keeps doing it even if I take the gas nozzle out and try to reseat it.
    It will typically put in half to one gallon before clicking off again. I know the gas tank is nowhere close to full when I start, so that’s not the issue.
    I end up watching the amount of gas being put in and guess when it’s probably close to full, since I don’t want to keep doing it and risk an overflow.
    Neither car does it all the time, and I can’t figure out why they do it sometimes and other times they’re fine. I’d say they’re fine at least 80-90 percent of the time.
    Do others find this happening too?
    Thanks.
  2. Fifen
    Fifen Member
    77
    31
    Utah
    This was happening too a some gas pumps. I fixed it by not putting the nozzle all the way in.
    I read some things online saying that the fumes coming out can sometimes trick it into stop filling
    SM-G965U ?
    BradC likes this.
  3. ChapmanF
    15,557
    The flow of air/vapor coming back up the filler neck is exactly what's supposed to trip the nozzle off, that's how they're built.
    Calibrating it right is tricky, and newer cars do a lot more to capture vapor during refueling than old ones did, so in a car like the Prius you'll find a bunch of extra hoses and valves up the filler neck that the car sort of uses to emulate the older car that the nozzle is expecting to see, and trigger it to trip off at the right time.
    It's still hard to build something that way and have it work right with every pump.
    My habit is to never squeeze the nozzle past the first, slowest, click. Maybe it takes a tad longer to fill the tank, but I hardly ever have the trip-off-early problem. The slow rate ends up not being too much for the nozzle.
    If I'm passing through a state where they don't allow the nozzles to have clicks, then I stand there and hold it squeezed to about where it feels like the first click would be. Usually goes fine.
    I occasionally hit a finicky pump that insists on clicking off early even then. I don't go back to that pump.
    BradC and Ed Beaty like this.
  4. BradC
    BradC Member
    42
    25
    Thanks for the replies. Good to know it’s not a problem with the car. I didn’t think so, but you never know.
    Tim Jones likes this.
  5. Tim Jones
    Tim Jones Senior Member
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    One time I tried to see how much fuel I could get in my v and it screwed up the gas gauge. It would read incorrectly until i drove it a few days then filled back up normally.
    #5 Tim Jones, Jan 12, 2020
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Like it showed empty for those few days after the extreme full fill up?
  7. Tim Jones
    1,706
    553
    SE Texas
    2011 Nissan LEAF
    I can't remember..... I think it wasn't going down.... I posted it on here long time ago and I was informed just drive 200 miles or so and then refill till pump shuts off and that was it.... worked fine since.
    CAUTION: Do Not Fill up a Prius v all the way to the top..... I mean to the top where you can see the fuel.
    You Will be Sorry for a couple of days. ps... might be the same with prius.
    #7 Tim Jones, Jan 13, 2020
  8. Siward
    Siward Active Member
    296
    124
    Toronto
    I had a gas pump clicking issue, but not for the Prius.
    The gas pump clicked constantly for my 2011 Hyundai Sonata. In the end, my mechanic replaced the canister valve and evap canister. This repair would have been free if it was covered under emissions warranty, but my car mileage was too high. The gas pump clicking went away after the repair.
    Gas pump keeps shutting off help! | Hyundai Forums
    The cause is something about a ventilation path being blocked. I don't know if this applies to the Prius.
