Gas engine comes on
Discussion in 'Prime Technical Discussion' started by Richard Pace, Apr 2, 2019.
  1. Richard Pace
    Richard Pace New Member
    Pittsburgh
    2018 Prius Prime
    The gas engine always comes on when it is around 30 degrees F and I have driven 1.9 miles. Why does this happen? The battery is full and everything is set to the most efficient mode. Prius Prime 2018.
  2. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    Are you going up a hill and/or accelerating at that point? If I am using a particular on-ramp to the highway, the same thing happens to me in cooler temps.
    52,395
    welcome!
    prime is not meant to drive in pure ev at all times. in colder weather, engine starting at a particular point in a commute usually means a change in speed and/or topography
  4. Salamander_King
    Salamander_King Senior Member
    11,024
    8,970
    New England
    And use of defroster will instantly turn on ICE. There are other situation not mentioned in the manual but Toyota engineers thought it would be best for the car to turn on the ICE.
  5. lllars
    lllars Junior Member
    32
    Southern Vermont
    2018 Prius Prime
  6. zorrobyte
    zorrobyte New Member
    Indiana
    2019 Prius Prime
    You have to keep in mind that Lithium Ion batteries aren't primarily designed for cold weather operation. Charging a lithium battery at freezing temperatures will permanently damage it which is exactly why Toyota installed battery heaters in the pack. Additionally, this is why the AWD model uses NiCAD cells for colder weather.
    Leaving ethanol-blended fuel inside a gas tank for too long is also bad news, ethanol absorbs moisture and can crystallize. Personally, I don't mind my engine burning some fuel every now and then to keep my fuel fresh.
    Lastly, while the heat pump heater can work in colder temperatures, engine coolant is still the best bet for HVAC operation below freezing.
    If you live in a cold climate with below freezing temperatures year round, you should have bought the AWD NiCAD model, or at least have a heated garage to maximize efficiency.
  7. bisco
    52,395
    but doesn't heating your garage so your car will be more efficient waste energy?
    (unless you're going to sleep out there:))
  8. lllars
    32
    Southern Vermont
    2018 Prius Prime
    Yeah, the awd model definitely would have been more practical for us, as we live up a dirt road in snowy vermont. But... not practical enough to compete with $10,500 worth of incentives on the prime ;-)
  9. HPrimeAdvanced
    HPrimeAdvanced Senior Member
    2,304
    3,519
    Anaheim, CA
    Doesn't everyone sleep in their garage! I do so to watch over my "baby", to make sure she's safe and comfortable!
    And what's this 14° nonsense; I've never heard of such a thing; isn't it always 60° to 100°?!!
    AChoiredTaste.com
  10. jb in NE
    jb in NE Senior Member
    2,233
    1,599
    Nebraska
    2018 Prius Prime
    Is there such a climate other than Antarctica?
    Salamander_King likes this.
  11. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    i live live in a cold climate with below freezing temperatures year round,
    its called marriage ;)
    thats why i sleep in the garage. with my sexy new "primesse"
    and
    thats where the beer fridge is !!!
  12. jerrymildred
    jerrymildred Senior Member
    11,517
    14,158
    Tampa, FL
    True except there are no models with NiCAD. They are either Li-ion (Lithium-Ion) or NiMh (Nickel Metal Hydride).
