Gas engine don't start after a crash
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Getheavy, May 9, 2022.
  1. Getheavy
    Getheavy Junior Member
    Cluj-Napoca,Romania.
    Hello,first sorry for my english I will do my best to describe the problem , last year I was crashed by an VW Passat at the side the right part of the car , the owner of the Passat have a very bad insurance only last mounth I can took the car to repair by myself because the insurance company is not any more and require more documents and legal actions .
    I took to Toyota delership for finding the damage,they give me a whole list of problems and mecanical problems,all the right parts was damaged , I change all the mecanical parts but the engine dosen't start , the hybrid sistem works I was able to go only on electric motor few feet to move the car after I change the mecanical parts , I took the car to a hybrid specialist and he told me is nothing wrong with coils,spark plugs,fuses stuff like that and maybe need a new computer , car works fine until the accident after the accident car dosen't start anymore ,maybe someone has experienced the same problem like me .
    The car stayed a lot in parking lot but the 12V battery is fine I will post all the cods Toyota give it to me .
    Thanks in andvance any help will be aprecied.
    52,393
    is it trying to spin the engine? the p0a08 is a bad hybrid battery
  3. PriusCamper
    PriusCamper Senior Member
    13,067
    5,306
    Pacific Northwest, USA
  4. mr_guy_mann
    mr_guy_mann Senior Member
    4,089
    1,997
    NJ-USA
    There may be a problem with the High Voltage Battery- but you need to fix the P0351. Each of the 4 ignition coils sends a signal to the ECM when each one produces a spark. If any coil doesn't send a signal at all, the ECM will not allow the engine to run.
    It could have a bad coil, or damaged wiring. You have to check the IGF circuit from coil for cylinder 1 all the way back to the ECM (or try substituting a new coil).
  5. Getheavy
    My fried ho work at the car he is a hybrid battery specialist , he tell it's no problem with the hybrid sistem , thouse cods are exactly after the crash now I have only the : P0125 , P0351 and P0A80, the engine starts for I don't know 3 secounds after turn off
  6. Doug McC
    Doug McC Senior Member
    1,082
    420
    Midwest
    2022 Prius
    On my 2022 Prius Nightshade (and I assume on all other Gen4’s and earlier generations) there is an emergency shut off system that is activated when a severe impact accident occurs. The system isolates the hybrid system and stops the fuel pump.
    It requires resetting that my manual says must be done by the dealership. From your description of your accident, it is most likely what your problem is. Perhaps someone on here actually knows how to reset it.
    JohnPrius3005 and xliderider like this.
  7. PriusCamper
    13,067
    5,306
    There's probably a setting for that in Toyota Techstream...
  8. Doug McC
    1,082
    420
    Midwest
    2022 Prius
    Perhaps, I think what our OP friend needs though is something a little more definite. I’m reasonably certain that there is a reset button somewhere in the Prius, however, since I’m NOT CERTAIN, I await the input from someone who is.
  9. PriusCamper
    13,067
    5,306
    yes... I mention it because I've not seen the setting yet myself, but I bet others on here have and look forward to knowing.
    Doug McC likes this.
  10. Getheavy
    I took the car to another shop , the guy ho work there was a former electrician for Toyota maybe will help , I will post here if he fix the problem and what the problem was , thank you for the answers .
    Doug McC and PriusCamper like this.
  11. PriusCamper
    13,067
    5,306
    An auto mechanic who is a former electrician is well positioned for the electrification of cars. If I had a dollar for every auto mechanic who expressed fear of electricity in hybrid and BEVs I'd be able able to afford a Project Lithium pack!
  12. Getheavy
    Well in my case was the stranges thing and maybe was only a coicidence or not , the problem was the LPG ECU , I haven't mention I also have a LPG system on the car and somehow the LPG ECU mess with the gas engine if I remove the fuse from LPG system car stars without any problem, tomorrow I will try the car to see if runs right .
    JohnPrius3005 and PriusCamper like this.
  13. PaulDM
    PaulDM Active Member
    616
    319
    UK
    2022 Prius
    Excel
    LPG Hybrid. That’s novel. Facepalm.
  14. Doug McC
    1,082
    420
    Midwest
    2022 Prius
    GREAT! Cool car too! LPG!
  15. Getheavy
    Well in the est part of Europe is a lot of hybrid Toyota or Lexus with a LPG conversion because here gas is very expensive for exemple now 1 litre of gas is almost 2$ and the LPG is less than 1$ so that's why a lot of people here convert their cars to LPG because of the cost , I don't have any problems with the engine or the LPG conversion this is the fist time but it's a cheap fix it's nothing expensive .
  16. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
