Gas Engine Running While In Electric Mode?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by dougjoe, Jun 7, 2012.
  1. dougjoe
    dougjoe New Member
    los angeles
    Hey all -
    I'm confused about my PIP. Every night, I charge my battery fully and have 11-12 miles of charge to consume during the day. However, I've noticed that at least 10-25% of the time I'm driving in EV mode, the EV indicator goes off and my gas engine just runs. It's not because I'm driving the car hard - it even does it when stopped at a light. My only guess is that either Toyota wants the gas engine to run once in a while or else it's trying to charge the Hybrid battery (even though I'm not using it at that time). Anyone have any insights?
    It's a really bummer because even though I'm rarely out of EV mode, I'm burning what seems like a fair bit of gas - after 300 miles of mostly EV, I'm down to half a tank of gas?
  2. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Are you running the A/C ?
  3. bielinsk
    bielinsk Gremlin
    505
    115
    Anaheim
    2013 Chevy Volt
    Or heat? I have found that Power mode can cause my engine to kick on as well.
  4. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
    Or defroster?
  5. rogerv
    1,639
    317
    Actually, any mode in which the fan is on can cause the ICE to run. I just mentioned A/C because the OP indicates he lives in the Los Angeles area, where we have been having fairly warm weather lately.
  6. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Still in EV mode (the green square above the speedometer), but without the EV indicator (the car symbol on the Eco-Meter) illuminated means the engine is running to warm the coolant. That triggers when you accelerate hard or when you exceed 62 mph.
    Outside vent (temp "LO" setting) will not.
  7. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Once it's started - which has been covered by a variety of posters - the ICE will run until water temp hits 130°F. At least that's been my observation so far. Once it hits 130° F, the ICE will drop out below 100kph (62MPH) if you let up on the pedal. You can put it into ICE mode in a variety of ways - heater, A/C, quick acceleration - doesn't have to be hard acceleration, a mild uphill can pop you into ICE mode - all of those as well as pushing the HV/EV button.
    One workaround is to power down (red lights in traffic are your friend here) and restart. Obviously, you can't do this on the roll, or while you're on the freeway, but at a traffic light, it's gold. It takes no more than 3-5 seconds to complete the workaround.
  8. bisco
    51,155
    does the ev indicator light go out when the engine comes on because you turned the heat on? my engine has never come on in ev so i have no idea. and don't confuse ev mode (light on left side of display) with ev indicator on right of display that simply tells you when you're in ev while in hv mode.
  9. john1701a
    12,797
    5,280
    57
    Yes, anytime the engine is running while still in EV mode... which indicates it has switched to EV-boost.
    The car-shaped symbol on the screen will become a hollow frame.
    The square above the speedometer remains unchanged.
    Photos of each will be available in the upcoming User-Guide revision.
