Gas engine turning on & off rapidly in rush hour traffic with hot weather and AC running
Discussion in 'Gen 2 Prius Main Forum' started by local_host, Apr 28, 2007.
  1. local_host
    local_host Junior Member
    75
    The other day I was driving home from work- stop & go traffic, about 5/10 miles per hour for about 45 minutes (yeah I know it sucks). It was pretty hot outside (almost 90 degrees) so I had to keep the air conditioner on. I understand that the gas engine has to kick on when the battery starts to run low, but this time it seemed really annoying. Everytime I would accelerate a little, the internal combustion engine would turn on, and then when I hit the brakes to slow down (not stop) it would shut off. There were about 2 bars left in the battery so I assume this is the reason. Perhaps if I shut off the AC, it wouldn't have been as bad, but it was just too hot outside.
    What I don't understand is why doesn't the ICE stay on till the battery is recharged more than just one or two bars? Therefore it wouldn't need to power on and off so rapidly, charging a tiny bit at a time. I wouldn't mind all that much but everytime the ICE comes on, the car jerks a little bit and I can actually "feel" it, and it's very annoying when it happens every minute as I'm accelerating and decelerating in the stop & go traffic.
    By the way, each time I accelerated in the traffic that day, I wasn't pushing the pedal hard enough to trigger the ICE to come on, I can tell because when I'm driving normally I can sense when it's in electric mode from light acceleration and gas mode in heavier acceleration (under 40 MPH). I just got this car in January so I have yet to have the experience of driving in the heat during rush hour. Is this normal??? Man I would hate to get caught in a hurricane evacuation when everyone has to drive 10 miles an hour for about 10 hours in the extreme heat (like what happened in Houston back during the 2005 hurricane Rita evac) AND have to endure the ICE repeatedly shutting off and on like this every minute........
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 02:11 PM) [snapback]431768[/snapback]</div>
    The reason is b/c it's very inefficient for the ICE to run and just charge the battery. It's "waiting" for you to start normal driving again where it can take advantage of optimum RPM range. The condition you described is normal and makes the best of the alternatives. Best thing you can do is turn the AC to a lower setting (ie higher temp...I usually use 78-80 degrees) or turn it off and roll down the windows to ventilate.
  3. local_host
    75
    <div class='quotetop'>QUOTE(efusco @ Apr 28 2007, 02:21 PM) [snapback]431772[/snapback]</div>
    Thanks for the suggestion, but that's just not reasonable here in Texas. In my opinion TX is THE hottest state in the US. Even though places like Phoenix and Las Vegas are constistently in the 110s in the summer, here in Texas we consistently get into the 100s BUT with much higher humidity which makes the heat index up in the 115 range. Add the "heat island effect" of a big city and the temperature might be even higher...
    I simply cannot have the AC at 78-80 degrees with the windows cracked in the sweltering heat. And it's not even summer yet, so the daytime heat right now is just 'mild'. Not too mention I don't want to have the windows open because when sitting in rush hour, the smell from everyone's exhaust is really nasty (especially from the big commercial trucks). Exhaust fumes seem to smell stronger in heat and humidity.
    If this is "normal" for the Prius I might have to consider a trade after this year...
    By the way, sometimes I get fast food and then eat it in the parking lot with the AC on. After the battery runs low, the ICE kicks in for about a minute, shuts off, and doesn't come back on for at least another 5 minutes. But when driving in rush hour with the AC on, the ICE kicks in every single time I (lightly) push the accelerator (not every 5 minutes). What's up with that??
  4. Tideland Prius
    16,443
    Why about tinting the windows or adding sunshades (if tint isn't your thing)??
    Also, the engine won't come on to recharge (stay on that is) unless the battery is almost at the 1 bar / 2 bar threshold. Only then will it idle and charge to 3 bars.
    If you're still well within the 2 bar area, then it'll cycle on and off as you've described.
    Also, your car is still relatively new. The engine shut down is still rough when it's new so it will smoothen out as the car ages. (I think it took nearly a year for me since I bought it in Oct 04).
    The other option is to use the A/C more haha and drain the battery to that 1 bar so that the engine will come on. I think using the front defroster might even help idle the engine.
  5. local_host
    75
    <div class='quotetop'>QUOTE(Tideland Prius @ Apr 28 2007, 02:46 PM) [snapback]431786[/snapback]</div>
    Yes, tinting is something I plan to add in the near future. However, the effects of cooling down the car will be negligible. I think people underestimate the heat in Texas. It is BRUTAL. Just think of sitting in a sauna with all of your work clothes on. That's what it feels like in a car, in TX, in the summer sun, in rush hour traffic, with no AC (or AC on at a high temp).
  6. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 02:39 PM) [snapback]431780[/snapback]</div>
    I just can't imagine trading in just b/c the ICE cycles on and off...try driving the car for a few more months, this is something you'll become accustom to. Worst case you can set the AC to "max cold" and the fan on high and that'll pretty much keep the ICE on almost all the time so you don't have to deal with the cycling.
    And, 78 is a fairly comfortable temperture...if the sun is shining right on you cooler may be necessary to feel comfortable, but it's a reasonable temp, IMO...and I wasn't suggesting using 78 AND opening the windows...it was an either or. Option. It gets into the 90s and 100s where I live (with 100% humidity) too, so I can relate to the circumstances and find I do just fine at 78-80 and my family doesn't complain at 78 either.
    Like I said though, give yourself a little time to adjust.
  7. local_host
    75
    That's good to know the roughness of the ICE turning on will decrease as the car gets older. I certainly HOPE that's true. Before I bought this car the only other hybrid I drove was the Honda Civic, which apparently is not the same kind of 'hybrid' as the Prius, as the Civic's gas engine didn't seem to shut off everytime you took your foot off the accelerator like the Prius does. The only time the Civic's engine shut off was when idle, so I never really 'felt' it come on and off the same way ..
    Not sure what you mean about using the AC more to drain the battery to one bar? The other day in traffic I had the AC on during the entire 45 minute low speed commute home.
  8. local_host
    75
    <div class='quotetop'>QUOTE(efusco @ Apr 28 2007, 03:01 PM) [snapback]431791[/snapback]</div>
    Again, 78 is NOT comfortable for me. It might be for you, but it's not for me. Why should I have to sacrifice my comfort level for a car that I just paid $27,000 for?? Where do you live? Missouri? Are you familar with Texas heat??? It comes early and stays late. "Summer" here is April through November. Also keep in mind that big cities are hotter.
    Btw, I did have the AC set to max. Not initially, but after this on/off cycling issue I tried the maximum and it didn't change anything. Maybe there's like a software error in the computer. It just doesn't seem normal for the engine to turn on and off so much. I mean every single time I stepped on the accelerator it came on, and every single time I let go, it turned off, all under 10 MPH or so.. Ever been in horrible rush hour traffic where you have to do this every few seconds?
  9. alexstarfire
    alexstarfire New Member
    220
    You should try it with the defroster setting, like windshield defroster only. That thing always makes my car run, even when the battery is fully charged. I do have a 2002 model though, so it could be different for you.
    BTW, I'm from Texas and know what you are talking about. Been during the summer and winter months. Summer isn't even that bad. I don't believe I've been there in 100+ degree weather though, as I haven't been during the summer in many years. I do however live in Georgia now, and the summer here is just as long. Started in early March this year and except for like 1 week where it went back to winter it's been over 70 degrees everyday so far. I've already seen 90+ according to my Prius, but it was probably closer to 85 and it's not even the peak season yet.
    I just roll two windows down about an inch or two and I'm usually just fine, even when I'm stopped at a light. I've noticed how having two windows open gives you more of a draft, presumably because the air flows between them.
    My $.02.
  10. onlynark
    onlynark Member
    189
    bay area
    I think someone mentioned in another thread about how to charge the battery. As far as I remember, you press the brake, then press the gas pedal to the half way point. That should turn on the engine and charge the battery.
  11. Charles Suitt
    Charles Suitt Senior Member
    1,637
    17
    Dallas TX
    :) Hi local host...
    I'm not sure WHERE in Texas you live (sounds a lot like Houston), but in the Dallas Summer (frequently, we have up to 25 or more days over 100º in the Summer), I have found my Prius, both the 2004 traded for my current 2007, to NOT cycle the ICE excessively. I normally set the A/C to "Automatic" and in the hottest days at about 74º to 76º. About the only other city in Texas with consistently higher temperatures is Wichita Falls. I have never felt the need to lower the windows for ventilation. As for a "reasonable" temperature, when it's 105º outside, 76º or 78º seems reasonable to me.
    Evan has offered good information and advice. From what I've read, your Prius is functioning as designed. Maybe you are hypersensitive to heat, some folks are. Ultimately, YOU are the only judge regarding what is comfortable for you. Don't be concerned about being "down to one bar," the MFD display only shows the SOC of your main battery between 40% and 80% - your Prius computers will maintain that range of charge automatically.
  12. brick
    brick Active Member
    1,083
    79
    Upstate NY
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 04:17 PM) [snapback]431797[/snapback]</div>
    Ever try it in a car with a stick shift? THAT is the pits in 5-10mph stop & go traffic. 45 minutes of that and you may as well have walked home, particularly if it's an older car with a stiffer clutch pedal. Been there, done that, in 95F+ temps and high humidity in a car with black leather seats and an aging A/C system.
    I guess I don't see what the big deal is. The gas engine turns on, the gas engine turns off...that's what a Prius does. It's just trying to save you some gas, which is what Toyota designed it to do. At least YOU don't have to do anything but step on the accelerator when you want to go and step on the brake when you want to stop. Am I missing something here? Like Charles said, the car takes care of its own health so you don't need to worry about anything bad happening while this is going on.
  13. Wetnabber
    Wetnabber New Member
    23
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 02:56 PM) [snapback]431790[/snapback]</div>
    Come on! Get Real! I have lived in South Texas for 30 years and it's no worse than the midwest in the summertime. Air conditioning is nice, but it isn't a "have to have" thing. The temp may get hot here in Texas, but there is always a breeze.
  14. NuShrike
    NuShrike Active Member
    1,378
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 12:17 PM) [snapback]431797[/snapback]</div>
    Setting A/C to max just makes your situation worse. You have to understand how the Prius works. First, 78-80F in the automatic settings is not actually 78-80F. It actually feels like 73F-75F if you keep the vents on you. When the A/C is on, add 5F against your targeted temperature. When the A/C is off, subtract 5F. Lower the temps a couple more F on the A/C if you have passengers. The A/C is also a guess gauge.
    Second, since the Prius's compressor is electric, it means you kept the H/V battery drained so your stop/start engine in traffic just got worse because you never let it hold any of the charge you would've reclaimed from braking. The Prius only charges the battery the minimal it needs in stop-n-go traffic to maximize MPG.
    Third, get some ceramic based tinting (or anything that rejects solar IR, not just light) for the windows so the A/C is not working against the green-house effect. Ask your tinter to demonstrate performance with a heat lamp and tint samples.
    Fourth, take off your thick clothes. Seems obvious, but I've seen people that don't understand the obvious. Antibiotic soap for example ...
    I live in Southern California and I've done this in 2 hours of 100F+ stop-n-go in LA traffic through 50 miles of commute (one way) with A/C set to 79F (78F if temps go above 102F), so I know better than what you're talking about. I have ceramic tinting on from Huper Optik, btw.
    ps There's another guy on these forums guy who survived driving out of the Katrina refugee traffic on one tank of gas because he understood when to use the A/C.
  15. Bob64
    1,540
    93
    Virginia
    Does the ICE turn on if you let it "crawl"?
  16. efusco
    19,891
    1,194
    Nixa, MO
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 03:17 PM) [snapback]431797[/snapback]</div>
    Don't be offended. You asked the question and we're offering options. But you need to be realistic about the matter as well.
    I've had my Prius for 3 1/2 years and almost 60k miles of driving experience with it. I've driven in all kinds of heat and cold, ice/snow/rain, cities during rush hour and isolated dirt roads at night. The outside temperture is not really relevant to the inside temperture and most humans find 78 a very comfortable temperture at rest, but you certainly have the right have a different degree of comfort.
    I've you have to have the cabin temp at 65 degrees for some reason that is certainly your choice and I'm not telling you to sacrifice anything, I was simply trying to offer some options that will reduce the rate of consumption of your battery's power supply so rapidly and the sensitivity of the accelerator in those conditions. The more energy your car needs and the lower the battery SOC the more sensetive the accelerator will be to turning on the ICE.
    Again, you seem very much overly sensative to the ICE starting up. Set the AC wherever you must to be comfortable. Drive the car. Turn up the radio and just drive the car. I think you'll become a lot less sensitive to the ICE cycling as you become more comfortable with the car.
  17. NuShrike
    1,378
    <div class='quotetop'>QUOTE(Bob64 @ Apr 28 2007, 02:05 PM) [snapback]431830[/snapback]</div>
    Sometimes, but usually only until it gets into the blue bars. If one really doesn't care about the MPG, try putting it into B-mode. It'll keep the engine on (depending on how you enter the mode), but you'll experience a lot of engine braking too.
  18. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(efusco @ Apr 28 2007, 01:01 PM) [snapback]431791[/snapback]</div>
    I concur. That's a pretty silly reason to want to trade in a Prius if you ask me.
    To the OP, yes, it's normal when the battery is low. Sounds like he'd rather have it running the whole time and wasting gas.
    <div class='quotetop'>QUOTE(local_host @ Apr 28 2007, 12:44 PM) [snapback]431780[/snapback]</div>
    It takes a LOT more energy to move a car from a standstill than to sit there idling. http://priuschat.com/index.php?s=&show...st&p=403689 mentions it takes ~300 watts for the Prius to maintain itself. I'm sure this is w/the AC compressor not running. (Even when the AC button is on, the compressor will cycle on/off).
  19. jamarimutt
    jamarimutt New Member
    985
    The on/off cycling described in the original post is common under the described circumstances and rather upsetting. You lift your foot from the accelerator, the engine turns on, you brake a couple of feet ahead and it turns off, and so on. And, the shudder does not go away as the car ages, mine has 62,000 miles on the odometer and still shakes as good as new.
    When this situation happens to me, I usually turn the air conditioner off (I keep it at 75 degrees). If it's too hot or raining, sometimes I step on the brake and press the accelerator half way to keep the ICE running. The battery will charge and the cycling will stop until the battery goes back to pink bars.
  20. Tideland Prius
    16,443
    <div class='quotetop'>QUOTE(jamarimutt @ Apr 28 2007, 05:18 PM) [snapback]431877[/snapback]</div>
    You wonder how HCH owners deal with it lol.
