Gas engine working, electric motor not working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by zcoach, Jul 10, 2013.
  1. zcoach
    zcoach Junior Member
    Blytheville, AR
    My 2010 Prius' electric motor was not engaging, in any mode. No warning lights were on. The gas engine worked. How do you check the inverter to see if it is bad?
  2. El Dobro
    El Dobro A Member
    6,984
    3,215
    If there was a drivetrain problem, you would have warning lights in the display. What makes you think there's a problem?
  3. zcoach
    Blytheville, AR
    Electric motor was not coming on. When in B no brake action. Would not go to EV mode. I went back and noticed the brake vent was partially covered. It seems to be better but still not EV mode.
    49,694
    what is a brake vent? is it hot in arkansas?
  5. El Dobro
    El Dobro A Member
    6,984
    3,215
    If the car moves, the electric motor is working. That is how the Prius works. Now, if the car isn't going into EV mode, that means the conditions aren't just right for it to activate. EV only works when certain conditions are met. If you're not getting any warning lights, you should be ok.
  6. bisco
    49,694
    how are the mpg's?
    JMD likes this.
  7. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    Car can't move without both electric motors working.
  8. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    As others have said, if the car is running and there are no lights on the dash then the motors are ok. Here is something that you can do to convince yourself though - put the car in reverse. If you can back up then the motor is fine - reverse is not powered by gas, only the electric motor.
    It does sound like you have an issue with the vent in the back. Keeping this clear and functioning is very important. If the hybrid battery overheats you can have problems like you mention in your first post.
  9. zcoach
    Blytheville, AR
    Sorry, battery vent. MPG are down. Motor is on but it will not not go to EV mode.
  10. fuzzy1
    10,254
    Does the dashboard give you an error message when you press the EV button? It so, what does the message say?
    EV mode has several restrictions, including minimum battery SOC, minimum engine coolant temperature, maximum traction battery temperature, maximum speed (which varies with temperature), maximum power or acceleration, and probably some more that I can't remember.
    When EV is locked out by by high battery temperature, MPG also suffers. Is your car baking in the sun during a heat wave? A blocked battery cooling vent also contributes this is. Some readers have also reported loud fan noise from this vent when hot. If the battery is hot but the fan noise is absent, that could also suggest fan malfunction.
  11. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I had this happen to me twice when I was using the car hard on a hot day. I think the battery must have got too hot and the car tried to avoid using it by running the engine with only minimal EV use. In fact the engine was revving at about 2,000 rpm all the time. No error messages and this was only temporary and stopped when I gave the car a rest.
    I didn't hear any HV battery fan either.
  12. zcoach
    Blytheville, AR
    Thanks to everyone for the advice. I think the battery being hot may be the problem. I will keep an eye to confirm.
