Gas fill over 10 gallons?!
Discussion in 'Gen 2 Prius Main Forum' started by batboy, Apr 20, 2011.
  1. batboy
    batboy Junior Member
    Fredericksburg, VA
    Before I explain, I have easily read over a hundred posts with few directly relating to this topic. Therefore, I wanted to post and get some opinions.
    I recently (this past weekend) filled my gas tank at a gas station I do NOT typically use. Like always, I set the pump until it clicked off. I did not top off. When I saw how much it was I couldn't believe it. 10.4 gallons! Keep in mind I have never, in over a year and over 100 fills, ever gone over 9 gallons let alone 10. Yes, I have read that many go over 9, but out of all the posts I have read only one went over 10 gallons and that was after he topped off. I did not top off.
    My first reaction was a badly calibrated pump and I was considering making a complaint. However, I am now ready to refill, at least I thought. I went to refill and noticed my gauge still read 3/4 full (7 pips) and I had gone 252 miles. I typically get around 400 miles before the last pip starts flashing. As a result, I did not get any gas yet. I wanted to see how far I could go before the gauge tells me to get more.
    My concern is I have ruptured the bladder and the safety hard tank is filling up. I have done nothing to justify a rupture, but what else could it be? Assuming this is a consistent issue, will I need to take it to get fixed? I am reserving judgment and trying not to overreact, but I must admit I am rather concerned. Thoughts?
    Matt
  2. Patrick Wong
    18,210
    6,513
    You don't have to worry about a ruptured bladder. The fuel tank contains a sensor that will detect fuel vapor in the space between the bladder and the shell.
    It is most likely that, on your last refueling, the fuel pump allowed a greater fill than normal. My estimate is that ~2 US gallon capacity remains after the fuel pump clicks off the first time, under "normal" conditions.
  3. batboy
    Fredericksburg, VA
    Excellent! I did not know about the sensor to detect vapor. Good to know there. I have read enough posts to not be surprised by severe fluctions in filling the tank; however, I thought this was extreme. I remain calm, but certianly need some validation. I hope to get that in the next few days. Thanks for the input!
  4. dogfriend
    7,512
    1,190
    Carmichael, CA
    I've gotten over 10 gal twice since owning the car; both times I had gas spurting back out the filler pipe though. :madgrin:
  5. sorka
    sorka Active Member
    1,026
    198
    Merced, CA
    2019 Prius
    I once put 23 gallons of gas in my SC400 which only holds 19 gallons if you actually run out of gas on the road. I hadn't run out of gas yet, so the pump was off by at least 4 gallons and probably more.
    Needless to say I did make a complaint to the state weights and measures board.
  6. ystasino
    ystasino Active Member
    793
    50
    Tucson, Arizona
    Is this estimate from mpg calculations? Care to elaborate?
  7. Patrick Wong
    18,210
    6,513
    My estimate is based upon the additional range achieved when my 2001's fuel tank was filled to the brim and overflowing, due to the fuel pump nozzle failing to click off at the normal time.
    Although no damage was caused to the fuel tank emissions control components, I don't recommend that owners deliberately overfill the tank since damage could result.
  8. batboy
    Fredericksburg, VA
    I'm currently at 430 miles with still two solid pips left. I usually fill up before I hit 400. I have gone over 400 before but the dash was screaming at me to get gas. I'm going to try to make it home today before a fill up. That will put me near 500. At 50mpgs that's right at 10 gallons which would corroborate what the pump told me when I filled up last. We shall see. *fingers crossed*
  9. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    I am one who always fills over 10 gallons and also top off.As I have been boasting on this forum my last tank of fuel I traveled 700.1 miles :jaw:
    But it also took 11.5 gallons to refill so you have absolutely
    no worries
  10. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
  11. Cessna157
    Cessna157 Junior Member
    25
    Orlando, FL (Walt Disney World)
    Wow! My normal fill up is almost never above 8 gallons. Being able to squeeze 10 in would be nice
  12. fgoodyear
    fgoodyear New Member
    187
    Tillson, New York
    Well..... it is an 11.9 gallon tank. I have put in 0ver 11 gallons when down to 1 pip and it is blinking and telling me to put in fuel soon. Technically if it is an 11.9 gallon tank, 11.9 gallons should fit, right? I put 10 gallons in regularly when I am down to 1 pip. If you run the pump slowly you will get more in before it kicks off. Run the pump at full speed and you will never get it full. It will kick off sooner. Figure your gas mileage by miles and where the gas gauge is to see how many gallons you used. You will see that you come up short on how much gas you should have left, therefore your tank wasn't full. The bladder in a Prius is not like a regular solid tank in other cars. It has to burp the air out as it fills, like a bag. Some people have said they have had gas shoot back out when the pump shuts off. That is because the air has to escape somehow. Run it slow and it doesn't do that, and you will get a fuller tank. Done it for 87k and never had a problem with ruining anything by topping off.:rolleyes:
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    No, not right. The 11.9 gallon specification is for gross capacity. The maximum amount you can add during refueling is the usable capacity, which is always less than the gross. In the case of a Gen II Prius it is considerably less, given the volume consumed by the bladder.
    Tom
  14. stefano5777
    stefano5777 Member
    380
    47
    Well maybe I have a Prius with a big bladder since I consistently put over 10 gallons of fuel with last fill up over 11 :0 I am a slow filler I do not like to stop for fuel but after reading all this I guess I have to stop more often
  15. qbee42
    18,058
    3,079
    Northern Michigan
    Ten gallons is on the high side, but not unheard of, especially since you live in a warm climate. Generally the fuel bladder consumes one to two gallons of tank capacity.
    Tom
  16. fgoodyear
    187
    Tillson, New York
    Have to disagree with 11.9 being inaccurate..... I have put in as much as 11.5 before. If I am on the last pip and it is blinking I can always put in 10 gallons +
  17. stefano5777
    stefano5777 Member
    380
    47
    I have put in 11.5 as well before. know one is disputing that you cant put that much fuel in what is being said is by stretching bladder to its limits can cause it to burst which we all know would be very bad!
  18. qbee42
    18,058
    3,079
    Northern Michigan
    The 11.9 gallon figure is the gross capacity of the tank. Part of that capacity is displaced by the fuel bladder, part is unusable fuel. This makes the net capacity less than 11.9 gallons.
    On the other hand, the published tank capacity does not include volume in the filler hose and other related nooks and crannies. If you insist, you can overfill the tank and use the extra capacity contained in the hoses. This will somewhat offset the unusable capacity of the tank, although it's not a recommended practice.
    Tom
  19. wjtracy
    wjtracy Senior Member
    11,370
    3,608
    Northern VA (NoVA)
    Matt- I live pretty close to you, I get 10+ gal fill-up occassionally in summer heat only. Not since last September. However, we did have that stretch of 85F+ weather a week or so back. Does it correlate?
    I am thinking the bladder expands in the summer heat.
