Gas gauge bar Issue
Discussion in 'Gen 2 Prius Fuel Economy' started by eman08, Aug 26, 2016.
  1. eman08
    eman08 Active Member
    360
    192
    US
    Anyone experience putting like let say 3-4 gallons of gas at the two pip mark and when you turn the car on, the pips roll all the way to 10 bars full? Is that even normal because that's not even a full tank? I'm aware of the bladder. Any idea of how many gallons left on two bars and one bar?
    49,500
    every bar is about 1.2 gallons. but since you're aware of the bladder, you know that isn't true.
    eman08 likes this.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    The gage won't register less than 3 gallons, so if you were to put in a couple here, then later add more that could explain it. Hope that makes sense to you.
    Gen II Prius is funky on the gage with the durn bladder, but I think you already know this.
    Main thing is won't see two gallons added, must be a minimum of three gallons added at a time for the gage to register anything.
    Gen III seems to not exhibit this problem IMO
    eman08 likes this.
    49,500
    trade for a 2010.
    eman08 likes this.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Gen 2 bladder does a phenomenal job of controlling gasoline vapors. Cherish this thought. Because it greatly hinders knowing how much gas you have.
    Fill the tank. Set the trip meter. Get gas in 375 miles. And repeat.
    Or carry a 3 gallon can with you everywhere. Your choice.
    eman08 likes this.
  6. eman08
    360
    192
    US
    Yeah I just bought it about a month and a half ago financed. I bought it or $7K with 160k miles on it off the lot. You think that's a reasonable price?
  7. bisco
    49,500
    no, but really what's reasonable is pricing in your area. and i have no idea where that is.
    on the plus side, they say it's good for prius to be driven, so you have a younger, high mileage car. that's a good thing. my daughter has an '08 with 100k, runs like a champ. she can't figure out the bladder either.
    eman08 likes this.
  8. fuzzy1
    10,170
    Based on various past reports from Gen2 Prius drivers, somewhere between 0 and 4 gallons left. It is highly variable from car to car, even season to season as temperatures change.
    Yes, a very few drivers have run out with 2 bars showing. I believe some of them were able to get gauge re-calibrations to fix it. More have run out a few miles (3 to 10) after the last bar started blinking. And a substantial number have had no bladder issues at all, going a couple gallons beyond the blinking bar.
    You won't know how much fuel your particular car has without testing it out on the road.
    eman08 likes this.
  9. bisco
    49,500
    take 5 gallons of fuel and do a midnite run until empty. use caution and quiet back roads or a parking lot.
    eman08 likes this.
  10. eman08
    360
    192
    US
    1472355278491.jpg Did alot of Hwy driving all day. I highly doubt I just only used 1.2 gallons lol. It's a guess gage all right. I ran my last tank all the way to the last pip and filled it up completely with 9 gallons of gas for $19 yesterday. Not bad. I guess that gauge is going to drop faster eventually.
  11. dorunron
    3,318
    1,103
    Houston, TX
    When you last filled up, did you top off? Also did you fill it at a fast rate of flow or a slow rate of flow? First Pip usually last's the longest on the Gen II.
  12. eman08
    360
    192
    US
    Not quite. I'm gonna have to check my gas line for any dirt and the Charcoal canister because when I was filling up yesterday at the BP gas station, the nozzle repetitively kept shutting off every 5 secs. Took me a little bit to get all that gas in. Funny thing is, this never happened before at any other gas station.
  13. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    We do not know where you are, the US is a big place.
    Here in MS, in summer I was able to get over 11 gallons in my Gen 2, in winter about 8. (get gas in the warmest part of the day, the bladder expands easier. I also found I filled up better with the nozzle upside down)
    So in the Summer I often got 160 miles before the first pip disappeared yet in winter sometimes as few as 40.
    That is no sign you will get similar values.
    eman08 likes this.
  14. eman08
    360
    192
    US
    I live in Iowa. I expect my Hybrid battery to last a very long time as heat is bad for Hybrid batteries. :) The car is not that old and bough it with 160k miles 2nd hand. We have alot of straight roads and hills here. I can hold a Glide on a electric for a good amount of time like my last picture.
  15. dorunron
    3,318
    1,103
    Houston, TX
    As Jimbo above has pointed out, filling the bladder can be tricky and you really just never know what to expect. Ours would normally fill at a slow rate (first notch on auto fill). I usually stopped after the first click off. A couple of pumps I did have to rotate the nozzle upside down to be able to fill. I also found that if you run the bladder all the way down, it is hard to fill back up. Seems like once it fully collapses, it does not like to expand very easily. You might try filling up when you hit two pips rather than going all the down. See if that helps. If you uptrade to a Gen III or IV, you will find the bladder is no more.
  16. Kevin_Denver
    Kevin_Denver Active Member
    581
    422
    Denver, CO
    Do not experiment with running out of gas unless you know what you're doing. Often once the car runs out of gas it will throw a code and will have pumped air into the gas lines rendering it unstartable, which will require towing the car to a mechanic to fix the problem. Also as you've shown, the gauge can be wildly inaccurate, and people have ran out of gas with one bar showing (without it blinking). Therefore my rule of thumb is to always fill when it shows 2 bars when I'm in town, and 3 bars if I'm on a longer trip.
    srellim234 and dorunron like this.
  17. dorunron
    3,318
    1,103
    Houston, TX
    The above is sound advise for a Gen II Prius IMO.
  18. 09Prius2
    09Prius2 Member
    201
    88
    FL
    During the summer in FL I have been able to put over 13 gallons into the tank on several occasions. Based on this, I was able to calculate that the low fuel indicator activates with around 1.8 gallons remaining. I allowed 70-80 additional miles around town for these last 1.8 gallons, just to see if that was the case. I know its not advisable to run out of fuel, but it was just an experiment. I ran out twice, knowing there were gas stations within a few blocks. I made it to the station on battery both times.
    I don't know how this would apply to a cold climate, but I would say that whenever you're on the road, fill up whenever it goes low. If you're always near a gas station it won't be so much of an issue, but you can definitely not have any certainty of how many gallons you have in the tank at any given time. On one road trip where I added over 13 gallons on departure, I had gone over 150 miles before the tank moved from full, when in fact I was probably down to less than 2/3 of a tank.
  19. srellim234
    srellim234 Senior Member
    1,198
    1,687
    Laughlin, Nevada
    We always try to fill ours at two bars too. We're never sure how much gas it will take but we know we'll never run out by filling it that way.
    Looking over the notebook I keep, we've filled up on one bar left three times, taking on 6.9, 8.7 and 9.1 gallons.
    With two bars left I've put in as much as 9.4 and 10.1 gallons.
    All at the same station on the same pump.
    With that type of inconsistency we just play it safe.
    dorunron likes this.
  20. CooCooCaChoo
    CooCooCaChoo Senior Member
    901
    504
    Cow-lee-fornia
    2023 Prius
    Yep. Definitely have to play it safe. My best practice is to always look to refuel after driving a distance equal to the amount of gas you put in last. So if you refilled 6 gallons, you can safely drive approximately 300 miles before you need to look for a gas station.
