Gas gauge inaccurate?
Discussion in 'Prius c Technical Discussion' started by Lenwood, Apr 13, 2012.
  1. Lenwood
    Lenwood Junior Member
    53
    san Mateo ca
    my gas gauge was down to 2 bars today.my distance to empty read 2 miles till I run out. What's up with that? Anybody experience this?:confused: I filled up and it took 9gallons
  2. Kirkuleez
    Kirkuleez New Member
    220
    24
    Oshkosh, Wisconsin
    Yup, that's normal with the c. I usually get a little over 8 gallons.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. SageBrush
    SageBrush Senior Member
    11,627
    2,530
    Southwest Colorado
    I see the same thing in my CTh. My days of trying to run the tank almost dry are over, so I try to add fuel within about 20 miles of the car request.
  5. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    when your range hits 0 then the last bar will be only light and it flashes, Ive driven 20-30 miles after range hit 0 no problems and still only took about 9 gallons. so its very conservative.
  6. outhouse
    outhouse Member
    125
    37
    auburn ca
    same her but only took 8.5 gallons.
  7. hpauly
    hpauly Junior Member
    Waterloo Ontario
    2018 Prius Prime
    Upgrade
    Well tonight driving home my range was less then 5km and the single bar came up flashing, and I was at a gas station within 2km.
    So thinking that 0km left would mean the tank was pretty much empty I filled the car and was surprised to see that it only took 31.7L to fill the tank.
    The car specs indicate that the tank is a 36L size so I had about a 4l reserve, which is enough to go another 100km.
    Not that I would try that.
    I see some people on Feully getting over 800km on their vehicles. I would like to know how they managed that has the best I could do before it hit 0 range was 717km
  8. sph101
    sph101 Prius 4
    156
    92
    32
    Brevard, NC
    2018 Prius
    Most cars have between 1 & 2 gals of gas in reserve when they show empty or the idiot light comes on.
  9. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    the miles indicated on the info screen isn't the range of when the gas runs completely out.. it is used as a guide.. and it says "cruising range".. which isn't the same as "range before gas is empty"... besides... there's always going to be a reserve.
    you shouldn't push it too much though.. but you can still get 60+ miles after the cruising range goes to zero and the gas light starts blinking at you.
  10. walter Lee
    1,126
    376
    Maryland
    I programmed my ScangaugeII to display the amount of fuel I have left in my 2010 Prius gasoline tank using the Xgauge Flv. Strangely or maybe not so strange - the Flv display level seems to changes with the angle of declination the Prius . The Flv reading fluctuates more often than the Prius MFD and normally display a higher amount/level going uphill and lower amount/level for going downhill.
  11. donny612
    donny612 "Captain Jack Sparrow"
    117
    Apex, NC
    I've never taken gas guages or even trip computers as "gospel" particularly where empty is concerned. I generally refuel on or about 1/4 tank. Especially when I'm somewhere where I don't know where the next station is, and because I'm used to a full size V8 truck that only got 15 mpg, so having a gallon or two left is much more crucial.
    In the case of my C, with two bars remaining, I'm beginning to look for a gas station anyway, but at a much more relaxed pace. I always fuel at MY convenience...not the car's!;)
  12. Oldwolf
    Oldwolf Prius Enthusiast
    816
    107
    NC
    2016 Prius v wagon
    Well, since the C has 10 bars on the tank gauge, and holds nearly 10 gallons, I'm hoping one bar = one gallon.
  13. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    And I was hoping that maple trees dropped leaves of real gold.
    I've never seen a linear gas gauge. There is no reason to expect one on the Prius c.
    Tom
    fuzzy1 and onlineid615 like this.
  14. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    Like I said, I am hoping....:rolleyes::D
  15. nutleyfrisbee
    nutleyfrisbee New Member
    Los Altos, California
    I have the same red Prius C. How are you getting 58 MPG ??
    Whats your secret ?
  16. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    A different commute? Slower speeds? Hypermiling? As they say, your mileage may vary. :)
  17. Surrylic
    Surrylic Junior Member
    122
    Winchester VA
  18. brucepmiller
    brucepmiller Member
    150
    73
    Michigan
    My indy mechanic advises to fill up before you get too fumes to keep from burning out your fuel pump. His mantra: "run from the top half, not the bottom half."
    Oldwolf likes this.
  19. Oldwolf
    816
    107
    NC
    2016 Prius v wagon
    I have a Gen2 also so when I bought my C I already had a lot of HSD experience. What works well on the Gen2 seems to also apply to my C.
  20. mremaximus
    mremaximus "I can't wait to start hammering people" Bubbles
    98
    From parts unknown...
    Does the C tell you estimated mileage for a tank? How come I haven't seen this...
