Gas gauge is not full?
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by DKTVAV, Oct 18, 2015.
  1. DKTVAV
    DKTVAV Active Member
    510
    101
    First time after more than three years, I filled up my gas tank today and it's only nine bars? I always fill it up when the last bar starts blinking with beep: it's been around 8.2 gls - 8.4gls every time and today is not different. Is it easy to fix? I don't want to start keeping track of the odometer when the gas gauge is not accurate anymore.
    49,501
    that happens to me once in a while as well. sometimes it goes to 10 after a little driving, but not always.
    WilDavis likes this.
  3. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I've noticed similar behaviour with the ChuggyPig, (to the OP) don't agonise too much about it, I expect your odometer is accurate, at least consistent, so the gauge on the gas-pump must be accurate (it's the Law!) so keeping a log over time sounds like your best plan, and at least it will be accurate! hope this helps - Wil
    merged
    Also: Check out the downloadable User-Guide to see what it says about running out of gas (p.20) https://attachments.priuschat.com/attachment-files/2015/10/95919_Prius_User-Guide_iconic.pdf - Thanks Ron!
    #3 WilDavis, Oct 18, 2015
    dorunron and bisco like this.
