Gas Gauge not functioning
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by mamamonkey, May 25, 2010.
  1. mamamonkey
    mamamonkey New Member
    While on an 800 mile drive yesterday, my gas gauge stopped working. The day previously dear hubby left the lights on and drained battery. We recharged it and followed manual procedure. Everything else works fine, but gas gauge. Can this be connected to battery problem or just a coincidental problem?
  2. Patrick Wong
    18,200
    6,474
    What behavior does the fuel gauge exhibit?
    It is normal, when 12V power is lost, that the fuel gauge needs some time to reset.
    If you are unsure as to the amount of fuel in the tank, I suggest that you fill the tank now.
  3. mamamonkey
    The line of indicator squares does not change representative of amount of gasoline used. On this last filled tank, I have driven over 200 miles and finally one "block" has been taken off. At least, it's doing something, but not normal.
  4. Patrick Wong
    18,200
    6,474
    OK, that is why that indicator is known as the "guess gauge".
    Don't worry about it for now. See if normal fuel gauge behavior resumes after you've consumed 2-3 tankfuls. In the meantime, use the MFD or trip odometer to keep track of distance traveled since last refill, so that you don't run out of gas (assume your fuel tank has a 9 gallon capacity, to be safe.)
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It should reset as you use it.
    Tom
  6. mamamonkey
    Thanks Patrick. That's what I'm doing. Hopefully it will correct itself.
