gas gauge problem
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by deed, Dec 12, 2012.
  1. deed
    deed New Member
    Hello Everyone: I have a Prius C One. I shut the car off and filled up the fuel tank. Then I started the car, and I have no idea why but I shut it off and then restarted it. The gas gauge did not register that I filled it up. It stayed at 160 miles, that was the reading it was on when I stopped for gas. Now I'm wondering how to correct it. Can anyone advise me. Thank You!
  2. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    The Prius manual warns owners that topping off the tank may not register the additional gas right away.
    Having only traveled 160 miles, that's a small enough quantity to fit that situation.
    Just wait it out. Eventually it will self-correct. Next time, drive further before refilling... and welcome to the forum.
  3. deed
    deed New Member
  4. deed
    deed New Member
    Thank you John, I will try that. I wonder if the mileage left to go, is what the car uses; or does it know if there is more gas in the tank than is registered on the miles left?
  5. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Moved to the proper Prius c forum from the Prius v forum.
  6. deed
    deed New Member
    Thank you!
  7. col127
    col127 Member
    345
    Illinois
    Mi
    I have noticed this same issue, however mine never self-corrects!
  8. deed
    deed New Member
    Hi col127, I wonder if there is a way to correct it?
