Gas gauge reads less in the morning than when I left it the night before
Discussion in 'Gen 3 Prius Main Forum' started by Slugdoc, Mar 22, 2012.
  1. Slugdoc
    Slugdoc New Member
    50
    Bronx, NY
    I imagine it's due to evaporation that happens overnight...
    Is it?
    And if so, would I save gas by filling it up more frequently? (Less room for the gas to evaporate into if I keep the tank more full)
  2. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Are your temperatures fluctuating? My guess is that it's due to the "bladder" in the gas tank expanding and contracting with the temperature changes. There shouldn't be any evaporation going on into the outside air as that is a violation of EPA regulations.
  3. royvogel
    royvogel TanzMan
    Smyrna, GA
    How about the air temp? Gas expands when warm and contracts when cold. Indy cars use liquid nitrogen (-325f) to cool their fuel before filling up for the race!
  4. Slugdoc
    Slugdoc New Member
    50
    Bronx, NY
    No Bladder in the 2011, as I understand it.
    Not talking about evap to the outside. Rather - within the closed feul tank, there will be liquid fuel in equilibrium with gaseous fuel. THe more empty space in the tank, the more gaseuos fuel, relatively.
    It is cooler in the morning. That could be it.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    If anything, mine adds a pip from the night before.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    The Gen III Prius does not have a fuel bladder. The bladder was used only on the Gen II NA models.
    Modern fuel systems are sealed to prevent evaporative losses. The one on your Prius self tests at night; any leak would throw a code, causing a warning light on the dash.
    Fuel gauges in cars are not precision instruments, so don't expect precise readings. They are also damped, so you won't see quick variations. My guess is that your parking situation introduces some variation in the displayed level, but there isn't enough time for it to react when you pull in to park. Starting the next day you see the variation.
    Tom
  7. p00kienrayray
    p00kienrayray Active Member
    720
    135
    Long Beach, CA
    Maybe someone is taking your car for a spin while you're asleep?:D
