Gas gauge recalibration?
Discussion in 'Gen 3 Prius Main Forum' started by Frogerelli, Nov 21, 2018.
  1. Frogerelli
    Frogerelli Junior Member
    38
    Fort Smith, Arkansas
    I have a 2010 Prius II, 77k miles. It seems like within the two or three months, it has taken less fuel to fill up the car than the gauge would indicate it needs. Last night, the gauge was showing the flashing lowest bar and the distance to empty calculator said 6 miles. I filled it up and by that I mean that after the nozzle clicked off, I very slowly pumped in more gas until it clicked off several times. I even shook the car side to side to let any possible air bubbles out of the tank. According to the gas pump, the car took 9.7 gallons when Toyota states the tank capacity is 11.9 gallons
    Is it possible the gauge is somehow out of calibration? Is there a way to reset/recalibrate it?
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    No calibration issues. People have been known to get around 50 miles after it starts flashing. I have seen very similar fill ups when I pushed it. They "error" on the side of safe. Also you will learn in time that the "computer" generated" mpg reads +3 mpg on the happy side. Example: If the computer says 50 it's more like 47 mpg. At 11.9 gallons you were getting very close to finding out why you DO NOT want to run out of gas in a Prius.
    The Gen II guys had problems though with the bladder tanks.
    #2 frodoz737, Nov 21, 2018
    Pluggo likes this.
  3. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    When DTE stops at 0, you have about 1.6 gallons left in the tank, states the many threads posted on here already.
  4. Mendel Leisk
    38,708
    You're looking for a solution to a problem that doesn't exist. The gas gauge is cautious, trying to prevent you have a perilous highway walk with a gas can. Fill up when it's moderately low, stop pumping when the nozzle kicks off, done. Trying to squeeze more gas in can lead to spillage, mess up the vapour control system.
    fuzzy1 likes this.
  5. BZzap!
    BZzap! Senior Member
    1,607
    877
    The Prius has a generous fuel reserve for obvious reasons: Running out of fuel in the Prius can be very problematic. Call it insurance. In my 5+ years of ownership, I have never had to put any more than 9.6 gallons in the tank. On several occasions I’ve had to ( according to the fuel gauge) run the car to below “zero miles remaining.”. Brinkmanship? Maybe, but understanding my car’s little quirks makes it a safe bet.
    RMB likes this.
  6. maurices
    maurices Member
    128
    37
    Sartell, Minnesota
    Same experience here. I have never been able to put in more than 9.8 gallons of fuel even after the low fuel light has been blinking. I too would prefer the gauge to be accurate not conservative.
  7. fuzzy1
    10,167
    This sounds about right. Only your expectations are out of calibration.
    It should take 11.9 gallons only if you actually ran out of fuel. Bob Wilson has done that many times as part of his engineering curiosity. For this particular issue, he ran more than 100 miles farther than you went. For details, read just the first post of this too-long thread:
    [WARNING] Running out of gas (Gen III) | PriusChat
    #7 fuzzy1, Nov 21, 2018
  8. bisco
    49,441
    Is this a new phenomena or did you recently purchase
  9. ASRDogman
    ASRDogman Senior Member
    6,085
    3,271
    Other than for an experiment, why would anyone WANT to run out of fuel????
    I found it's best, at least for me, to fill up between 1/2 and 1/4 empty tank.
    But you're playing with fire if you wait till the last marker is flashing....
  10. bisco
    49,441
    People don’t like stopping for gas.
    That’s why they invented plug ins.
    Full tank every morning
  11. BZzap!
    1,607
    877
    I can calculate that each PIP on the fuel indicator equates to one gallon of fuel. In turn , this calculates to about 50 mile per PIP. In terms of file gauge accuracy, it probably doesn’t get any more accurate than that. You just have to remember that the guage only reads 10 gallons. After that, your are into an emergency reserve of about 1.5 gallons. All this is based upon a rule of thumb average of 50 MPG.
  12. Johnny Cakes
    Johnny Cakes Senior Member
    1,016
    764
    Virginia, USA
    First, I echo Mendel Leisk's advice that trying to squeeze more gas in can mess up the vapour control system.
    Second, people seem to get upset that others are running close to empty and think its "stupid" not to fill up when there's still a substantial amount of gas left. I don't know why people feel that way. Stopping for gas takes time, especially on long trips when you have to get off the freeway. I think it is reasonable to ask what is the reasonable "no risk" assessment of what the gauge is telling you.
    Anyway, this thread is a good summary of how much gas is left:
    Third, no one has addressed the actual issue you raise in your post:
    What jumps out at me is that you have detected a change in the behavior of the gauge. That it took more gas to fill up two or three months ago and now it takes less when the gauge is still indicating the same is the interesting question in your post. Unfortunately, I don't have an answer for you, but maybe someone could explain this change in behavior.
    Mendel Leisk and bisco like this.
  13. bisco
    49,441
    agreed, that's why i asked the question in post #8
    Johnny Cakes likes this.
  14. Mendel Leisk
    38,708
    Yeah guilty as charged. :oops:
    Grit likes this.
  15. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Some fella here who I won't say his name, but he put a gen 4 engine into a turd gen and drives 125 miles after DTE is at 0.
  16. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    There's no emergency reserve.
  17. BZzap!
    1,607
    877
    Ok. Pucker factor Reserve; 1.5 gallons; after the fuel gauge indicates zero mile left.
