Gas Guage problem /resolution
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Al Winters, Mar 28, 2015.
  1. Al Winters
    Al Winters New Member
    Carver MA
    I'm buying an 08 Prius hatchback from a friend (with 36,000 miles). He's had the gas gauge problem for a few years, ever since Toyota had to correct a big electrical problem. I wasn't comfortable with having to fill up every 200 miles so we brought to the Plymouth MA dealer to see if they could fix it before I bought it. They did in about an hour. They said the fuel gauge just needed recalibration. NO CHARGE.
  2. Patrick Wong
    18,200
    6,479
    That's good.
    Even if the gauge was not fixed, there is no reason that you would have to refuel at 200 mile intervals. Use the MFD mpg and miles traveled gauges to determine fuel consumption, and reset both when you refuel.
  3. Yakoma
    Yakoma Active Member
    470
    124
    ATL-ish
    Is that a calibration that can be done with Techstream?
    49,732
    welcome, all the best with your purchase!(y)
