Gas Guage
Discussion in 'Gen 2 Prius Technical Discussion' started by Christine.Anderson, Jul 6, 2006.
  1. Christine.Anderson
    Christine.Anderson New Member
    Has anyone experienced this problem? I received the "beep" that I was running low on gas. I filled up, but it still is telling me that I'm empty.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You actually filled up the tank completely, or just added a couple gallons? If you don't fill at least 4 gallons the system doesn't reset and will indicate low fuel and won't reset the MFD.
    If you did fill all the way up and it's doing this there may be a problem with the sender from the fuel tank that needs to be checked by your dealer.
  3. eagle33199
    eagle33199 Platinum Member
    5,122
    268
    2015 Prius v wagon
    similar types of situations have been brought up, but i don't think it's been a serious problem for anyone. if you pumped less than a certain amount (i believe the threshold is 3 gallons) the gauge doesn't really register it. Also i think one or two people have posted saying it's taken the car a mile or two to recognize that it was filled and update the gauge accordingly... it's like a conventional car, you turn it back on and the needle starts to slowly climb back up :-p
    i wouldn't be too worried about it just yet. give it a little time to fix itself (besides, you know how much gas you put in it and what your MPG is, so you should know about how far you can go, hehe), but if you keep having the problem, might as well take it in and have ti looked at.
  4. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    This topic contains some good reading on the subject including instructions for calibration of the fuel gage:
    http://priuschat.com/index.php?showtopic=1...&hl=calibration
    I think the calibration tells the software that controls the fuel gage that the car is level. That most likely isn't your problem, but could be. If you use the search function on this site and do a search for "fuel gage" you can learn more than you ever wanted to know.
    Welcome to PC.
