Gas Lid Open Lever
Discussion in 'Gen 3 Prius Main Forum' started by jaredy, Jan 14, 2012.
  1. jaredy
    jaredy Member
    162
    SoCal
    I just noticed that... there is no gas pump sign on my gas lid open lever in the car? Do you guys have it? :p
    Just feel weird there was no sign....:eek:
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Mine does... Guess on the V,ATP they figure you know what that level is for. :)
  3. fuzzy1
    10,335
    Mine does too.
  4. frodoz737
    frodoz737 Top Wrench
    4,530
    2,437
    33
    Should be there. Make them fix it.
  5. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    What gas lid lever? Being a Prius owner, I've never used one.
    Tom
  6. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Mine does too.
    Wonder if the 11's don't for some reason? Any other '11 owners missing the "fuel pump" symbol on their lever?
  7. Lemooron
    Lemooron Junior Member
    73
    25
    Lemoore, CA
    My 2011 does not have it either. Build 11/11. I don't mind though.
  8. fulltank
    fulltank New Member
    230
    38
    Arkansas
    My '11 has the gas lever with the gas pump icon on the lever.
  9. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    Another bozo thread that makes me walk out to my car and look at something and to check on something else. My fuel door lever only has a fuel pump symbol on it. If you look on your display where the fuel gauge is you will see the vertical F-E display with the pips then to the right of that will be a fuel pump symbol with an arrow pointing left on its left side, indicating that fuel filler is on the left. I believe this pump and arrow symbol is a common standard across the automotive world for indicating what side of the vehicle the fuel filler is on.
