Gas mileage better with full tank!
Discussion in 'Gen 3 Prius Fuel Economy' started by Rickkiboi, May 4, 2023.
Tags:
  1. Rickkiboi
    Rickkiboi Junior Member
    17
    16
    Palmdale, CA
    I have a 3rd Gen , 217k miles (9k on rebuild), original hybrid batt that’s tests fine, running 215/45/17s.
    I get relatively good gas mileage on a full tank, about 52mpg. However after about 40 miles of driving, gas mileage drops down to 39mpg.
    This started before the rebuild around 207k miles.
    Any thoughts?
  2. Mendel Leisk
    41,485
    What was the rebuild about?
  3. Bill Norton
    Bill Norton Senior Member
    2,161
    736
    MONW, Ks.
    Who cares what that display says.
    The real deal is what a paper and pencil says at fill ups.
    ukulelegeek likes this.
    51,968
    it could be that when the tank is full, the pump struggles to push enough fuel, but once a little gasoline is replaced with air, better suction is accomplished
  5. Grit
    Grit Senior Member
    6,573
    4,227
    Wilkes Land
    I full tank on uphill driving and it get horrible mpgs. Half tank on the way back gets me twice the mpgs. Not sure why but I got the opposite result from yours
    Bill Norton likes this.
  6. Bill Norton
    2,161
    736
    MONW, Ks.
    Just to point out the obvious, you have a Level 5. I have one also, but those wheels and tires are never going to get you
    'Typical Prius fuel economy'.
    That's why I sold my 17" wheel set and now use standard 15" wheels and tires.
    I immediately saw a decent improvement! And the ride is quieter and less 'jarring'.
    It's weird how the Level 5's didn't have their own EPA numbers. They were definitely less efficient.
  7. Bill Norton
    2,161
    736
    MONW, Ks.
    Just to point out the obvious, you have a Level 5. I have one also, but those 17" wheels and tires are never going to get you
    They look nice and the handling is quicker/better! I believe it also has a quicker ratio steering rack.
